Trouble Maintaining Idle, acceleration Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
silveriodine
Post by silveriodine »
I have an 86 240DL manual trans. When I first start the car cold, I have to FLOOR it to get any kind of response from the engine, and even when i keep the pedal to the floor, the acceleration will die unless i pump the throttle for 5 minutes. When i start driving, the car will putter and jump and sudenly accelerate like a cartoon until it backfires once or twice and then it drives like a dream. Until, of course it sits for an hour, then i have to repeat the whole process. Whats wrong?
Volvord
Year and Model:
Post by Volvord »
I believe that year all 240's were fuel injected. If this is the case I would say that the cold start injector is not working, a common problem. To fix the cold start injector has to be repalce. The function is to supply additional fuel when the engine is cold, it performs the same function as a choke on a carbureted engine.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
