water in the cabin
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
portrona
water in the cabin
Post by portrona »
Hi,
I have a 740GLE. 120,000 miles. I have discovered a small pond in the rear driver-side foot-well plus water-logged carpet undermatting everywhere else. The sunroof drains fine through all four channels. Cant tell where it is coming from. Anyone got any ideas?
Portrona
LaRy
Post by LaRy »
In both front foot-wells you probably have airvents on the side walls, to be opened manually by a lever. If the vent frame is broken or not totally tight assembled to the wall, water will come in and get under the carpet. I had to use silicone to make this tight. Take the panels away and check it by pooring water into the air intake of the car. The drain water will pass outside this vent frame, and if it is not totally tight, some of it will get in and under the carpets.
Guest
Post by Guest »
Ive been having this same exact problem, thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Please disregard this post...
I'm marking threads for use in a planned beginning-to-end repair 'database,' and this one will be included, thus this message. There's no other way to mark threads save posting to them.
Thanks!
Also -> Amazon link
