960 Wagon 1995 Temperature indicator oscillates
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Nombert
Year and Model: 960 Wagon 1995
Post by Nombert »
Hello Volvo owners
:?: This is my first posting. I have a 960 Wagon and lately the temperature indicator hand has been acting funnily. It's oscillating when the motor is hot, it goes to warm (center position) when the car is cold. It has not yet gone into the red zone. Oil is ok. I asked a Firestone repair man, and he said the temperature gauge in the radiator has to be replaced, a $240 repair, 2 - 2 1/2 hours of time required. Thanks you for your input :)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Welcome to the site!
I'm not sure how hard it is on a 960, but on an 850 it takes literally 30 minutes to open the thermostat housing and fix the coolant temp sensor.
http://www.fcpgroton.com/product-exec/p ... emp+sensor
There's your part. Search 'thermostat replacement' on the site here to find a good write-up for the 850. Your location will be a bit different, but just follow the upper radiator hose to the thermostat. Really, the hardest part is just getting the bolts out.
'98 S70 T5
2016 Chevy Cruze Premier
Nombert
Post by Nombert »
:D So glad to hear from you. Will check it out and get the part from Boston Volvo. Might save me a bunch. Do you think coolant will run out if I remove the gauge? Thanks again.
jblackburn
It will come out of the top radiator hose as you remove the housing, and the coolant tank line can be pinched off with something. I used a big plastic slurpee cup from a football game to catch the spill over from the thermostat housing, or you can put a pan up under the car. Just fill it back up and you should be fine - there is no need to 'bleed' these cars as others require.
'98 S70 T5
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Your Firestone repair man is out of date with his information. The 760 turbo had the sender unit in the top of a metal radiator. The 960 has the sender unit mounted in the thermostat housing. If you are only replacing the sender unit it can be done without removing the thermostat. However, as the thermostat is usually the root cause for temperature fluctuations, it is good practice to replace both.
Has the check engine light come on, indicating a fault code has been set?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
