I dropped the pan and changed the filter/gaskets on my 240. I have the car back together and running now, but the procedure only replaced 3.3 liters (or so) of the fluid. Apparently there is a total of 7 liters in the transmission. Or close to that. I don't have the manual in front of me at the moment. I want to flush out the old fluid completely (or as completely as possible with the transmission installed). The manual suggests the method of draining the fluid 2 liters at a time through the fluid return line above the pan.
It says to disconnect the cooler return line, attach a clear tube to it, put the tube into a drain pan, and run the engine until bubbles show up in the fluid. Then stop the engine, add 2 liters of fluid, and repeat the process a couple times. Presumably this will circulate and empty most of the fluid volume in the transmission.
But it is very difficult to get to the bolt which holds the return line to the filter housing. I can just get to it with a wrench if I have the pan off. But the pan needs to be in place for the procedure. I can also get to it if I remove the exhaust. But I can't imagine I should be running the engine with the exhaust removed.
Do I need a special wrench for reaching this bolt while all the other components are in place? If I need to uninstall/reinstall the exhaust just to do this then I'll bring it to my mechanic.
Thanks all. I really enjoy reading the threads and hope to add my expertise to the discussions when I have any
Matt
