Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
1986 Volvo 740 ECU wiring
- Year and Model: 2000 C70
- Has thanked: 0
- Been thanked: 0
Hey guys! My 740 more or less tried to commit suicide
and torched a lot of the wiring coming from the ignition coil into the cabin. I know how to get the wiring going to the fuse panel out. But how do I remove the harness coming from the engine bay to the inside of the car? I want to tape that up and make sure what I can't see isn't burnt.
- Has thanked: 0
- Been thanked: 0
Re: 1986 Volvo 740 ECU wiring
It's not the engine harness, it's the harness going back from the coil THROUGH the firewall and then to the ECU and fuse panel. I wish it was as easy as the engine harness.
- Year and Model: 93:240/940
- Has thanked: 0
- Been thanked: 39 times
I don't own a 700 series Volvo...but from looking at this thread, specifically that diagram, I must assume coil and powerstage wires are bundled with headlight wires. So, start disconnecting, or splice what's needed to be spliced.slm987 wrote:harness going back from the coil
hall effect sensor location on 1986 740 wagon
by One to Remember » Sat May 07, 2016 6:51 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 12 Replies
- 2129 Views
Last post by One to Remember
Mon May 09, 2016 4:57 pm
1986 740 GLE Turn Signal Don't Work but Hazards Do
by dibovolvo » Tue Nov 22, 2016 11:11 am » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 2 Replies
- 1067 Views
Last post by dibovolvo
Wed Nov 23, 2016 9:23 am
1986 740 GLE alarm/ immobilizer issue
by tjg1019 » Thu Jan 03, 2019 2:03 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 1 Replies
- 138 Views
Last post by tjg1019
Thu Jan 03, 2019 5:14 pm
Wanted to buy 96 850 Turbo ECU in Houston, TX- Didn't need an ECU- Now need help!!
by dok33 » Sat Jul 09, 2016 4:01 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 11 Replies
- 1344 Views
Last post by tryingbe
Mon Jul 18, 2016 5:59 am
