I'll be performing maintenance on the server March 31. I'll try my best to make interruptions as painless as possible. Thanks for your understanding.
Did you know? 🤔
Fuel pumps were running continuously now won't run at all
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Maddenkm
Year and Model: 1986 240
Has thanked: 0
Been thanked: 0
United States of America
Maddenkm
Re: Fuel pumps were running continuously now won't run at all
Post by Maddenkm » Tue Aug 28, 2018 8:13 pm
Yeah, I might be willing to take that risk. But I'm gonna check out the 91 in the junkyard by me to see if I can find a newer ECU/FICM I can just switch out, but it's the only one I've found around here and it's been picked pretty clean. If I ground it to the chassis am I gonna need to add a switch so I can turn off the relay? Seems like that wouldn't be necessary since the ignition shuts off the relay and it's only the ground, but I'm not sure.
jimmy57
Has thanked: 3 times
Been thanked: 231 times
jimmy57
Post by jimmy57 » Tue Aug 28, 2018 8:20 pm
The control modules will work from 1985 through 1988 in your car. The 91 is a different system and has more wires in the module plug so your harness will not plug into that one.
Maddenkm
Has thanked: 0
Been thanked: 0
Maddenkm
Post by Maddenkm » Wed Aug 29, 2018 10:42 am
I regrounded the fuel pump relay to the chassis and sure enough the pumps started working, thank you! However, now I can't get the car to start. When replacing the IAC valve I removed the distributpr cap to create more room to work in, and I accidentally broke one of the plug wires pulling it off. I replaced them, but I did notice they weren't the exact same size as the old ones. Would that matter? AutoZone gave me the wrong size fuel filter a couple weeks ago so i think their database is a little off on these older models. I'm also thinking it might be a clogged fuel filter, which is basically the only part of the fuel system I didn't change. The guy I bought it from said he put a new one on when he got it, but that was about a year ago and he didn't siphon the old gas out before trying to get it started, so it could probably use a new one.
