1992 940 Sedan fuel injector o ring replacement
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 24 times
Re: 1992 940 Sedan fuel injector o ring replacement
Post by lummert »
I purchased a 12 piece (12 O-rings including a tapered tool for installing the O-rings) injector o-ring set fitting 1990's Ford Ranger 3.0L V6. The 12 piece set was about $3 cheaper than an 8 piece set. Replacing the o-rings is fairly easy taking perhaps 20-30 minutes.
1988 Volvo 760 Turbo Wagon
Herb Goltz
Year and Model: 2004 & 2006 XC-70
Post by Herb Goltz »
Others have noted that the leaking around the injector o-ring is often a sign that the injector has failed-- you might want to have one on hand when you take apart the fuel rail. The over-fueling of that cylinder might be the cause of your check engine light, but read the codes on the OBDI.
The 700/900FAQ at brickboard.com is a tremendous resource for these cars.
Nixwe
Year and Model: 1992 940 turbo
Post by Nixwe »
Sadly, I didn't get all of the parts as are in the picture above. I've only gotten the brown rings. Thank you everyone. I'll invest in all the right parts before I continue to move forward with the repairs. Otherwise, it'd be several trips of wasted time to and from the auto parts store.
Nixwe
Post by Nixwe »
I’ve had all the injectors, spark plugs, wires, lines, everything I could think of, replaced. After all the replacement parts were put in, no fuel leak and no smell until 2 weeks later. It came back. I need help.
