Hi,
4th 240 here. Bought it cheap as a barely running project car. Runs pretty sweet now, except sometimes it runs super rough after cold start, then a minute later it's like a switch was flipped and it runs fine but with a slightly high idle. Can't find any vacuum leaks with carb cleaner. Did a full ignition tuneup, cleaned throttle body, replaced IAC, Bosch O2 sensor, intank fuel plump, MAF. It threw an EGR code a couple of times, so I blocked off and uplugged the system. I'm wondering if it's the engine temp sensor? Thanks
Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
Very Rough Idle on Cold Start on Rescued Volvo
- Year and Model: 1992 244
- 297 Views
Last post by towanas
- 1195 Views
Last post by WhatAmIDoing
- 78 Replies
- 8080 Views
Last post by PeteB
- 757 Views
Last post by cuhfs
- 28 Replies
- 3241 Views
Last post by jking4020
