IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Radio Still Says "Off" After Three Hour Wait
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
HerrGruyere
Year and Model: 1998 V90
Has thanked: 0
Been thanked: 0
United States of America
HerrGruyere
Post by HerrGruyere » Mon Apr 08, 2019 7:50 am
Hi again,
My radio still says OFF even after waiting three hours with the key in position 1. I’ve tried removing the radio and disconnecting it for a second. Still says off. All the fuses seem to be okay.
Should I try disconnecting the battery and the radio? Does the key have to be in position 2 (running)?
Just checking. Thanks!
RickHaleParker
Has thanked: 3 times
Been thanked: 473 times
RickHaleParker
Re: Radio Still Says “Off” After Three Hour Wait
Post by RickHaleParker » Mon Apr 08, 2019 8:39 am
Power the radio off and leave it off until tomorrow. That always worked for me.
Are you sure you have the original radio? The correct code for the installed radio?
Slide the radio out and see if the code is penciled on top.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
HerrGruyere
Has thanked: 0
Been thanked: 0
HerrGruyere
Post by HerrGruyere » Mon Apr 08, 2019 8:53 am
Code on the radio is the same one given to me by Volvo customer service.
I guess I can keep the radio off for a while. Then maybe this afternoon try the key on thing again.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Apr 08, 2019 9:02 am
Did they look up the code by VIN number or radio serial number? Did they confirm it works?
tardcart
Year and Model: 96 850t. 93 940t
Been thanked: 37 times
tardcart
Post by tardcart » Mon Apr 08, 2019 10:29 am
how many times did ¥ou put the wrong code in? after three attempts it locks out for 4 hours of driving with the radio on.
HerrGruyere
Has thanked: 0
Been thanked: 0
HerrGruyere
Post by HerrGruyere » Mon Apr 08, 2019 1:40 pm
I heard it was only two hours of driving or leaving the key on. Also I didn’t put the wrong code in. The previous owner did. I’m just trying to get it back to code mode so I can put the right one in.
I used my VIN. But I also took the radio out to confirm the code given to me (they’re the same).
tardcart
tardcart
Post by tardcart » Mon Apr 08, 2019 3:38 pm
your right, 2 hours. . the key position 1 (if not driving) is sort of two and a half clicks where the warning light arn't on but the fan and radio have power. The radio should say OFF or something like that. when it says CODE you can put in your 4 numbers providing all you buttons work that correspond to your code.
HerrGruyere
Has thanked: 0
Been thanked: 0
HerrGruyere
Post by HerrGruyere » Mon Apr 08, 2019 7:16 pm
I would do the running position for overnight, but I don’t want the daytime lights to drain the battery.
My commute to work is an hour each way. Does the time have to be consecutive? Does the radio have to say OFF instead of actually being turned off?
Maybe this weekend I’ll put it in the garage and let it sit overnight with the key in position one.
precopster
Year and Model: Lots
Has thanked: 4 times
Been thanked: 108 times
Australia
precopster
Post by precopster » Mon Apr 08, 2019 7:25 pm
It needs to be 2 hours straight with no power interruptions. You may need to pull the globes (or the corresponding fuse) in the daytime lights.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Apr 09, 2019 1:08 am
That works if it is the original radio. The codes are stored in the radio. If you move a radio from one car to another the code moves with the radio.
Obtain original Volvo radio code online, "Official method" for dealing with OFF code. There is also a contact form for getting the radio code by radio serial number .
As I said before. Turning the radio off for a day has worked for me.
For the Daylight Running Lights. Look at the headlight switch in the lower right hand corner. That is not a screw, it is the switch for the Daylight Running Lights . Take a Jewelers screwdriver and turn the switch to turn Daylight Running Lights on or off.
