Top convertible Hydraulic Pump Topic is solved
tango_1000
Year and Model: c70 2007/ C70 2011
Has thanked: 9 times
Post by tango_1000 »
I have a 2007 C70 hard top convertible. I had recently a problem, the ceiling upholstery so when I was trying to open the convertible top it got hook in between. Basically I had to open and closed it manually. I follow the instructions from some guy, very nice video on youtube. Everything was looking ok and nice close but when I stared the engine and drive a bit, just in reverse from the driveway, and very loud alarm sounded and a red warning sign plus it showed "STOP SAFELY ROOF CAN BE DAMAGED"
When I was opening and close I have to pull the cable under the back seat to decompress the hydraulic system. At the end I push the brass top on the hydraulic pump in the trunk near the ski opening to get the pump to create pressure again.
I used vida to diagnostic the problem and at some point showed CRM-C052 Hydraulic Pump Supply Voltage Too Low, and
"Related CSC
Text window and warning symbol, Text message, IV
Sun/moon/convertible roof, Hard/impossible to open/close, SC"
So I wonder if there is something more I need to do the re pressure the hydraulic pump? reset?
Anybody with any help please.
Thank you everyone
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Watch this video at 9:30, May have your answer.
08 C702.5T (sold)
The non-Swedes:
tango_1000
Thank you, this is the video I follow the directions. Unfortunately my problem is past this instructions
Jonesroad
Year and Model: 2015 v60
Has thanked: 13 times
Post by Jonesroad »
did you reset the convertible roof module?
Krons
Post by Krons »
tango_1000 wrote: 03 Jul 2023, 12:40 Thank you, this is the video I follow the directions. Unfortunately my problem is past this instructions
Per the video at 9:45 pulling the cylinders back is a critical step to make sure the computer thinks the roof is latched…this was completed?
08 C702.5T (sold)
The non-Swedes:
Fidozzy
Year and Model: 2008 Volvo
Post by Fidozzy »
Good evening, were you able to find a solution to the low voltage? I am having the same issue currently
Lafcadio78
Year and Model: 2007 C70
Post by Lafcadio78 »
Me too, same problem, beeping, roof not closed.
How did you get on?
Anyone know Paul Mountain’s contact details?
