2011 C30 R Design 2.5T / subframe bolt
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Pretribrapper
Year and Model: 2011 C30 2.0 T5
Has thanked: 51 times
Been thanked: 6 times
Post by Pretribrapper »
Have an issue. Had to drop my subframe to replace a steering rack and I got that part done. However, when reattaching the subframe bolts I got all of them back in except the driver side front upper bolt. Part #31262063. It starts to tighten and then it just stops and I dont want to snap it. Any idea what could be the issue? I was told I should order a new bolt but I need to get car back together. Is there any substitute for this bolt that I could get at my local hardware store? Was curious if anyone has any idea. All other bolts went back in with no issue.
Has thanked: 1834 times
Been thanked: 1709 times
Can you swap this bolt to another location with another bolt to see if the issue is the bolt pr the thread it is going into?
