IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
V50 leak - passenger side front into the footwell
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
andream
Year and Model: 2006
Has thanked: 0
Been thanked: 0
Great Britain
andream
Post by andream » Sun Nov 20, 2016 7:50 am
Hi I have a leak on my lovely v50, it pours down the passenger side front into the footwell. I have tried everything, re-sealing the windscreen and all around the area. is this a common problem or am I just unfortunate? any suggestions/remedies would be appreciated. thanks :D
Reason: improved title
Has thanked: 7 times
Been thanked: 25 times
United States of America
Re: leak
Post by MadeInJapan » Sun Nov 20, 2016 2:39 pm
I think a lot has been written about this- it's the drains in the sun room...they are clogged or detached. If I find something more about this, I will post back.
Re: leak
Post by MadeInJapan » Sun Nov 20, 2016 2:51 pm
This thread should be a good place to start and I believe there are pictures as well as other links, etc. in it: http://forums.swedespeed.com/showthread ... light=Leak
tullys
Year and Model: V50 2009
Has thanked: 0
Been thanked: 0
Great Britain
tullys
Re: leak
Post by tullys » Sun Aug 05, 2018 1:54 pm
Hi
A couple of years later, but did you get this sorted?
I have a UK 2009 V50 _without_ a sun roof and have a leak coming down driver's RHS foot well, I think the water soaks into the foam backed lining on the wall to the front of the door and comes into the foot well. For 6 months I've been without carpets because it was soaked into the backing. Might have the same issue on passenger side too. So far all the hits I've seen for this have either been for the sun roof (don't have one) or other Vx0 models that have different air intakes under the wiper assembly.
Cheers
Colin
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 279 times
Canada
oragex
Re: V50 leak - passenger side front into the footwell
Post by oragex » Sun Aug 05, 2018 3:27 pm
There are indeed plenty of places where the water can come in. I have an S60 but I guess some components are similar. These are just a few more places to inspect, there are other similar videos on Youtube www.youtube.com/watch?v=rzpaJ4ulRic
TeddyBoo
Year and Model: V50 2005
Has thanked: 0
Been thanked: 0
Great Britain
TeddyBoo
Post by TeddyBoo » Mon Aug 06, 2018 3:49 pm
Had the same problem but nothing some silicone can't fix , but It still leaks sometimes when it's really pouring
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Post by MDK » Mon Aug 06, 2018 4:49 pm
What about a door gasket? Was the car ever side swipped? I have the same problem with my 2004 S 60 ... water seems to be coming in between the door and body of car.
tullys
Has thanked: 0
Been thanked: 0
Great Britain
tullys
Post by tullys » Tue Aug 07, 2018 1:03 am
Thanks for the reply,
Went through that video earlier in the year and used it as a guide to remove the carpets, which were soaking and are _still_ out, although now dried out.
Also back then I removed the shroud above the wiper assembly hopeful of finding a blocked intake but alas there was non-such.
I removed it again to recheck last weekend but the only items of interest were some plastic flaps that drain the area into the wheel arches. Apart from dropping on of those into the wheel arch and having to retrieve it (!) they both appeared in order and not blocked.
tullys
Has thanked: 0
Been thanked: 0
Great Britain
tullys
Post by tullys » Tue Aug 07, 2018 1:07 am
Thanks for the reply.
Never been damaged, owned since new.
Don't think it's coming from the door seal, from the pattern of where the water is coming from, I taped sections of paper along the whole interior to see which one got wet. Door seals in general are known as point of entry for leaks, I know some manufacturers use double door seals, so I've already had a look at it.
tullys
Has thanked: 0
Been thanked: 0
Great Britain
tullys
Post by tullys » Tue Aug 07, 2018 1:09 am
Thanks for the reply...
Did you seal along the whole front of the windscreen were it meets the wipers?
