Did you know? 🤔
Bad smell from AC, only when humid or rain outside.
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
beauvafr
Year and Model: C30 2011
Has thanked: 0
Been thanked: 0
Canada
beauvafr
Post by beauvafr » Tue Jul 11, 2017 8:55 am
I got that moldy smells rom AC some have. The smell only appears after rain, or on humid climate, and comes from the vents.
Here what I did to solve it, none of this worked.
  • Remove cabin filter, and put a AC cleaning solution with disinfectant directly to the evaporator (where the cabin filter is located)
    Spray the AC cleaning solution in the vent
    Let the AC work for couple of minutes
    Place a new cabin filter (charcoal activated)
The smeel goes away, masked by the scent. A couple days later, it comes back!!
I have also checked for water on the carpet, looking for a possible rooftop drain leak after a heavy rain. I found nothing. Anyway, the smeel is only coming from the vent, not the cabin itself.
I have run out of solution now..
Do you have any idea what I should do next?
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 286 times
Canada
oragex
Re: Bad smell from AC, only when humid or rain outside.
Post by oragex » Tue Jul 11, 2017 10:21 am
You may do this - use the cleaning solution that you already have
Alternately, you can also engage the recirculating button and spray into the intake inside the cabin - I think it's above front passenger feet but not sure exactly where.
All these without the cabin air filter in place, but with the cover installed.
Don't use bleach, it may corrode the evaporator. Some use Lysol.
GaryB1
Year and Model: 2008 V50
Has thanked: 0
Been thanked: 0
United States of America
GaryB1
Post by GaryB1 » Thu Jul 20, 2017 3:42 pm
A friend used these and had pretty good results. Meguiar's Air Freshener, New Car kits. He got it online from Walmart or someplace. It looks like a bug bomb for the house. You turn the car on, put the A/C on recirc and lock the top down on the cans and close the door until they have finished. He used two of them at the same time because the car had been smoked in. I don't know if it cleans or just masks odors, or how long it'll last, but it's been a couple months and so far seems good. My V50's previous owner loved Golden Retrievers and the back area has a distinct doggy odor when the direct sun hits it. I've been using Chemical Guys New Car spray, but I may try the Meguiar's Air Freshener kit if it doesn't help long term.
