Did you know? 🤔
Imobaliser try again issue Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Notrunning
Year and Model: 08 c30 2.0d
Has thanked: 0
Been thanked: 0
Great Britain
Notrunning
Post by Notrunning » Tue Dec 19, 2017 8:12 am
Hi I have recently had a flat battery on my volvo c30 2.0 d 2008 and replaced it, but cant start the car it wont start up at all and says imobaliser try again does anyone have any recommendations as to the issue I am facing
Thanks in advance
yagger
Year and Model: S60 2005 2,5T
Has thanked: 5 times
Been thanked: 25 times
Belarus
yagger
Re: Imobaliser try again issue
Post by yagger » Tue Dec 19, 2017 12:53 pm
Need error codes.
Volvo electronics and programming.Yagger&Doublebug - our experience invaluable.
Aftermarket Online Data Transferring Service for Volvo Pass: total
Notrunning
Has thanked: 0
Been thanked: 0
Great Britain
Notrunning
Post by Notrunning » Thu Dec 21, 2017 1:34 pm
I don't have a reader to read them it just wont start after I leave the car for a bit it trys i can here it try buy it is brief but then nothing , I just get imobaliser try again all this after a flat battery this is stupid
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 290 times
Canada
oragex
Post by oragex » Thu Dec 21, 2017 4:06 pm
Have the ignition key in POS II when jump starting the battery or when disconnecting/reconnecting the battery.
Try first cycling the key fob, close/open the doors a few times.
May also try disconnecting the car battery overnight
MadeInJapan
Has thanked: 7 times
United States of America
MadeInJapan
Post by MadeInJapan » Sat Dec 23, 2017 11:05 pm
You might try using the slim key to lock and unlock the car 3 or more times too...this reset things on the older model cars so don't know if it will on our cars or not but it's worth a try. Typically immobilizer issues have to do with lack of power somewhere- either in the fob battery or the main battery in the car itself.
Notrunning
Has thanked: 0
Been thanked: 0
Great Britain
Notrunning
Post by Notrunning » Tue Dec 26, 2017 4:13 am
I have left the battery disconnected overnight still nothing i held down the odometer button and turned the key this gives me a code of 264 of that means anything to anyone ?
MadeInJapan
MadeInJapan
Post by MadeInJapan » Sun Dec 31, 2017 7:27 am
Sorry- don't know what that code is.
mrbrian200
Been thanked: 80 times
mrbrian200
Post by mrbrian200 » Sun Dec 31, 2017 1:02 pm
I'd check all the various fuses first. I'm not sure where they all are on the C30. Be sure to check the ones on the CEM somewhere up underneath the dash. I'm not sure those are shown in the owners manual. They might be. Disconnect the battery before pulling random fuses to look at them or you'll likely get into even more trouble.
Notrunning
Has thanked: 0
Been thanked: 0
Great Britain
Notrunning
Re: Imobaliser try again issue  Topic is solved
Post by Notrunning » Thu Jan 11, 2018 11:58 am
Thank you all for you suggestions , I did try them but unfortunately nothing , had it towed to the stealers and they reloaded the ecm , all fine now , dreadfully really just due to a change of battery because it was going flat , it does say in yhe manual this is perfectly ok to to so bad on you volvo
MadeInJapan
MadeInJapan
Post by MadeInJapan » Sat Jan 13, 2018 4:42 pm
Sorry that this was the issue and caused you a great deal of headaches.
I hate it when I have toe resort to the dealer.
