Did you know? 🤔
Remote Entry Keys suddenly don't work at all.
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
JoeRiver
Year and Model: 2004 S40
Has thanked: 0
Been thanked: 0
United States of America
JoeRiver
Post by JoeRiver » Sun Mar 24, 2019 12:14 pm
Neither remote entry key does a thing, all of a sudden, on 2004 S40. Suspect electrical problem inside the car, as both
controller batteries wouldn't go kaput at once. First problem seems to be, 'how do I get into car?' :evil:
RickHaleParker
Has thanked: 3 times
Been thanked: 562 times
RickHaleParker
Re: Remote Entry Keys suddenly don't work at all.
Post by RickHaleParker » Tue Mar 26, 2019 12:11 pm
Use the Key Blade.
The metal end of the remote that looks like a hole for a key ring is one end of the Key blade.
Slide the spring loaded catch toward the side and pull the Key Blade out of the remote control.
The Key hole is under the plastic cover at the door handle. Find the hole and pop the plastic cover off with a tiny screwdriver. Don't let the cover go flying off where you cannot find it.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
JoeRiver
Has thanked: 0
Been thanked: 0
JoeRiver
Post by JoeRiver » Tue Mar 26, 2019 3:55 pm
Thank you. I figured out the key and got into car ok. Now it won't start. I had left the light switch in wrong position, due to mis-
undersdtanding the 'daylight running' nature of it. So battery was dead. Tried to get it charged, but it was feeble, so bought a
new battery. Still won't start; just clicks, though all the bells and whistles now work. Buying this car 'used' is stretching my 20th
century grasp on technology. Any additional advice will be greatly appreciated.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Mar 27, 2019 5:08 pm
The daylight running lights can be turned off in Vida using Vida 2014D and a good chinese DiCE clone. I did so on my 2003 S40.
Did you cleaned the battery cables before you connected them to the new battery?
Did you clean the battery terminals before connecting the cables?
Is the new battery fully charged?
Sometimes, it is something that small.
JoeRiver
Has thanked: 0
Been thanked: 0
JoeRiver
Post by JoeRiver » Thu Mar 28, 2019 10:40 am
Thank you all. I'm on it's trail. Suspect I blew a fuse or relay in trying to jump start it.
JoeRiver
Has thanked: 0
Been thanked: 0
JoeRiver
Post by JoeRiver » Thu Mar 28, 2019 2:08 pm
MAN FIX CAR ! Turns out it was fuse #23, which runs the fuel injection. I had checked them all, but only pulled them out one by one and looked at them from the side, as the book says. This time I checked their continuity with ohm meter, and found that lying no good bugger. Wonders never cease. Thanks again to all. This is a great forum. Hope my experience helps somebody.
