IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2015.5 V60 Strange Rumble Noise and Vibration Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
Anticus
Year and Model: 2015.5 V60 T5
Has thanked: 3 times
Been thanked: 0
United States of America
Anticus
Post by Anticus » Sun Jul 08, 2018 4:10 pm
Hi all,
I bought a 2015.5 V60 Drive-E Premier with 76,000 miles on it. Had the Volvo dealer check it out, and they gave it a clean bill of health. I bought the car and within 2 weeks, I have started to notice a horribly annoying and troubling noise accompanied by vibration coming from underneath the passenger cabin.
I thought it was a bad bearing or a stuck brake caliper at first, since it sounded and felt like a rumble from uneven pavement surface, but it comes from multiple directions at different times. It's a little more common when just starting to move, such as backing out of a parking space, and it lasts for about one second every time it happens. Usually about once every minute or two.
Slightly more common at low speed, and occurs while both stationary (engine running) and moving.
It occurs with A/C and fan on or off, and the only thing that I noticed on a walkaround is that the fuel door was cracked open (the cap was secure) and I just popped it back in to place.
The only thing I can think is maybe a fuel pump failure? Even then, I have no idea why the noise/vibration would sometimes come from the front of the vehicle.
I love this car but I'm sending it back if this sort of problem happens with no warning within two weeks.
johnson2bs
Has thanked: 0
johnson2bs
Re: 2015.5 V60 Strange Rumble Noise and Vibration  Topic is solved
Post by johnson2bs » Fri Mar 01, 2019 9:41 pm
I have the same problem with my S60 E-drive, Mine occurs at low speed, high speed and at a full stop.
These users thanked the author johnson2bs for the post:
Anticus
Anticus
Been thanked: 0
Anticus
Post by Anticus » Fri Mar 01, 2019 9:49 pm
I figured it out afterwards. It was the gas cap and the noise was the pressure equalizing after it built up too far.
AutoZone and Advance both sell a compatible cap which fixed the problem immediately.
No clue why that failure seems to happen, but if that's the problem that haunts these vehicles I think it's fine.
johnson2bs
Has thanked: 0
johnson2bs
Post by johnson2bs » Sun Mar 03, 2019 1:30 am
I bought a new Volvo gas cap OEM, I am still having the problem
PerfectBiscuit
Year and Model: 2015 v60
Has thanked: 0
Been thanked: 0
PerfectBiscuit
Post by PerfectBiscuit » Sun May 26, 2019 5:34 pm
If you're experiencing this problem try replacing the evap system charcoal cannister, Volvo part #31338102. In the meantime, keep your tank above 3/4 full as often as possible to help take stress off the fuel pump and lessen your likelihood of being stranded, as eventually it will prevent your engine from getting enough fuel. This problem drove me nuts until they finally figured it out. Apparently it's just now starting to show up on these vehicles as large numbers of them reach 70k plus miles. I suspect consistently running premium will help delay having to deal with this. Symptoms for me included difficult-to-locate light knocking sounds both moving and idle (eventually I determined it was coming from the rear), including after turning off ignition, as well as more pronounced rumbling noises and - my favorite - conspicuous fart sounds. Never could replicate it at the shop but finally one of the service writers knew what it was based on my description.
