IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2015 XC60 T6 48600 miles
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
kosterholm
Year and Model: s 60
Has thanked: 1 time
Been thanked: 0
United States of America
kosterholm
Post by kosterholm » Fri Sep 21, 2018 7:37 pm
have noticed oil comsumption to the rate of 1 quart per 1,000 miles. use 5-30w full synthetic, Houston Tx; anyone else have and issue like this? Mostly city driving, on the highway 2 or 3 times per month.
Thanks in advance
jimmy57
Has thanked: 4 times
Been thanked: 238 times
jimmy57
Re: 2015 XC60 T6 48600 miles
Post by jimmy57 » Sat Sep 22, 2018 10:32 am
Drive-E 4 cylinder or the 6 cylinder model?
kosterholm
Has thanked: 1 time
Been thanked: 0
kosterholm
Post by kosterholm » Sat Sep 22, 2018 2:49 pm
6 cylinder AWD
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 266 times
Canada
oragex
Post by oragex » Sat Sep 22, 2018 3:06 pm
Did you just purchase the car? Switched to synthetic ?
kosterholm
Has thanked: 1 time
Been thanked: 0
kosterholm
Post by kosterholm » Sat Sep 22, 2018 3:30 pm
have had car 3.5 years, dealer recommended synthetic 5-30, Quaker State. Been using it since I bought it. trying to find
out if other owners have had same issue, large problem or not.
oragex
Canada
oragex
Post by oragex » Sat Sep 22, 2018 3:49 pm
So it's not because of switching to synthetic - I assume the oil consumption started only recently.
The 2010 models (P3 as we call them) had a widespread PCV problem causing the engine to start taking oil at alarming rates with low miles. The PCV box is located at the top of the engine and easy to replace. This should be quickly addressed or it can damage the piston rings. The only reason I didn't mention it first is because I suspect by 2015 they had already used the improved PCV design, but who knows... maybe yours still came with the faulty designed PCV. Worth a check with the dealer, they should check the numbers and tell if your engine has the improved PCV box.
Just a link but there is more info on the net
www.reddit.com/r/Volvo/comments/40qk1g/ ... _guzzling/
www.volvoforums.com/forum/volvo-s60-v60 ... not-87076/
While there, Quaker State may not be the best oil out there, but that's another subject..
These users thanked the author oragex for the post:
kosterholm
jimmy57
jimmy57
Post by jimmy57 » Sat Sep 22, 2018 5:58 pm
Isn't it still in warranty? Get it checked at dealer.
kosterholm
Has thanked: 1 time
Been thanked: 0
kosterholm
Post by kosterholm » Sat Sep 22, 2018 6:42 pm
600 miles out of warranty, taking it in next week for evaluation; if it is rings or worse, going to ask for "Volvo goodwill" as I'm sure the problem began before warranty expiration.
thanks for your info,
