IPD sale XeMODeX - Experts in Volvo Electronics
MVS-Amazon link helps MVS!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
2010 XC60 tailgate won't stay up (goes up and down fine)
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
aaronlife
Year and Model: 2010 Volvo XC60
Post by aaronlife »
Hi All,
I am new to this group as I've just encountered my first volvo issue that looks tricky to solve, and I haven't found a solution to my issue in the threads.
I have a 2010 xc60 and the lift gate opens and closes fine, under power, but if I open it, when it reaches the open point, it slowly comes back down under the weight of the tailgate. If I press the close button, it closes quickly.
I replaced the right strut and that didn't help.
So, I am assuming there is some leak in the hydraulic system, but as the pump opens and closes it fine, I don't know where to start.
Failure of bleeding system, bad o-ring, I don't know where to start. I don't see any fluid externally visible, so I will have to pull off the rear interior cover, just looking to see if anyone has been through this, as the dealer costs make this prohibitive to bring it there, and even parts online start at $300+ for the hydraulic components, except for the hoses and o-rings.
Thank you,
Aaron
jimmy57
Been thanked: 276 times
Re: 2010 XC60 tailgate won't stay up (goes up and down fine)
Post by jimmy57 »
The one P3 with power tailgate via hydraulic system I ever saw had the seal on cylinder piston leaking. That is a typical hydraulic cylinder where oil pressure on one port extends and the other port retracts the rod. If the piston seal leaks then the cylinder rod will not stay in place. The other thing that could cause it is a bad solenoid as that also seals the system so the tailgate cylinder holds in place. You cn prop the tailgat open with a stick of the right length and then detach the cylinder end from tailgate. I could hear the fluid hiss inside cylinder on the one I repaired. I suppose a leaking solenoid would hiss inside tailgate as that is where the pump and module reside on XC60.
aaronlife
Post by aaronlife »
wow, thanks!! great info!
aaronlife
Post by aaronlife »
I haven't taken it apart yet, but I noticed that the hydraulic rod makes noise like it's rubbing on the inside, which I recall noticing before this failure started. i also noticed that if i catch and hold the hatch partially open as it falls, the pump eventually realizes it is partially open and turns on again to push it open, but if it slowly falls all the way to the bottom it just thinks it was manually closed and doesn't respond. does this suggest the hydraulic cylinder is the issue? that's my guess, but I wasn't sure how the solenoid works...
jimmy57
Post by jimmy57 »
The module has a pressure switch to stop motor at full open and that will run the motor if you grab it when it leaks down. Switches like that have a higher pressure point for one contact position and a lower one for changing contact position. I can push up on a properly functioning tailgate already open and get the pump to run. When it leaks down the pressure likely doesn't fall enough to trigger the pump but holding it lets it drop and triggers pump. None of that tells you whether the leak is solenoid or piston seal. you will have to listen closely while pulling it down to see if it makes noise and to determine whether that noise is from cylinder or from pump unit inside tailgate.
aaronlife
Post by aaronlife »
Gotcha thanks again, I really appreciate your clear informative response. Will do...
aaronlife
Post by aaronlife »
I disconnected the hydraulic piston from the hatch and couldn't compress it by hand, reconnected it and could hear the piston make noise as the hatch slowly closes, hard for me to say if it's normal noise or piston leak, but the hatch is falling faster now so the seal leak, wherever it is, is getting worse. I'll take off the hatch cover next...
aaronlife
Post by aaronlife »
Hey Jimmy,
So, the only noise I heard was coming from the piston so I ordered and replaced that this morning. No luck, it goes up easier, but still slowly drifts down. I did find a bad o-ring on one of the hoses attaching to the piston, it started leaking as soon as I removed the clamp that holds the 2 hoses to the cylinder end, but I replaced that and it stopped leaking and the hatch still falls down.
Where would I find the solenoid? In the pump, or the reservoir area? Can the solenoid be replaced without replacing the entire pump?
Would it fall if the system had air in it from a bad o-ring? Or low fluid (although I never saw a leak until today)? Is the system self-bleeding?
Thanks,
Aaron
aaronlife
Post by aaronlife »
I replaced the pump today with a used one and it goes up and stays up.
Now it won't go down when the button is pressed, so I'm letting it sit closed for awhile (manually closed it) and will see if it resets.
aaronlife
Post by aaronlife »
Swapped module on the new/used pump with my old module and the down button works fine now.
Issue with the pump must be the solenoid or one of the valves on top of the pump where the hose connects, because the tailgate stays up when the hoses are disconnected, so connecting the hoses releases the valve on the end of the hose, but the pump isn't holding the pressure.
