2010 xc60 idler shaft to alternator is loose
Dive pulley is wobbling for A/c drive and alt. shaft input Can't find a answer to repair. I have taken the motor down to the cover, but lack the special tools for gear holding inside the cover. also need special tool for the pulley removal. What bearing is needed for the shaft, can't seem to find one listed. Man do I nee help! 218,000 miles xc60 3.2
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 29 times
- Been thanked: 46 times
Re: 2010 xc60 idler shaft to alternator is loose
Paulii,
The 3.2 is a very reliable engine
And it is shared by Volvo and Land Rover.
Here is a Land Rover forum post that shows the bolt that can become loose
https://www.aulro.com/afvb/freelander-2 ... owner.html
This post from a different Land Rover board shows how to take off the manifold an expose the Alternator
https://www.freel2.com/forum/topic32245.html
While you are in there you should replace the Thermostat, small coolant hose and O-ring
This post has the part number for OAP (Overdrive Alternator Pulley) and a picture of the special tool need to replace it
https://www.freel2.com/forum/topic33867.html
Let me know if this answers your questions
Thanks
Paul
Thanks
Paul
