Radiator anti tamper device charging failure, lost communication with starter/generator volvo xc70 3.2 2010
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
Dcadizel
Year and Model: xc70 3.2 2010
Post by Dcadizel »
Does any one has experience with RATD ( radiator anti tamper device? I’ve replaced the device already. Also replaced alternator with correct one, and regulator. Permament codes cleared up in ECM but it still shows me U012000 „lost communication with starter/generator control module. Car is charging and voltage stays around 14.5. The message „charging failure, service urgent” comes and goes. Did test drive and car runs normally but when iddle there is small flickering of light from time to time. I susspect RATD is causing it. Did anyone experienced issues with RATD? I drive xc70 3.2 2010
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
Dcadizel wrote: 22 Jan 2025, 09:49 Does any one has experience with RATD ( radiator anti tamper device? I’ve replaced the device already. Also replaced alternator with correct one, and regulator. Permament codes cleared up in ECM but it still shows me U012000 „lost communication with starter/generator control module. Car is charging and voltage stays around 14.5. The message „charging failure, service urgent” comes and goes. Did test drive and car runs normally but when iddle there is small flickering of light from time to time. I susspect RATD is causing it. Did anyone experienced issues with RATD? I drive xc70 3.2 2010
You may still have a failing or incorrect pulley type on alternator.
Dcadizel
Post by Dcadizel »
I should’ve mentioned that. Yes, I checked pulleys, the alternator comes with new and it compensates as it should, the otber one that is connected by rubber belt coupling is tight, does not spin at all, it’s tight, also serpentine belt is moving as it should, the compensator pulley was replaced about 3 years ago. I does charge, and I have 14.5 when car is running but I noticed last week that cab light flickered few times. Vida did not show fluctuation but then in the cargo area I have 12v socket with voltage meter and voltage drops to 12.3v for split of sec every minute or so. I started to think the ACM (alternator control module) which is the voltage regulator that came with the alternator is faulty. It is a rebuilt alternator from FCP so i started to suspect somebody messed up…
giegaand1
Year and Model: S60 2005
Post by giegaand1 »
Hello, i have simillar issue, i have error code ecm-u028600 lost coms with anti tamper device and randomly popping out error in dash about charging. How did you solve your problem?
