s80 2.5 T engine
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
kielbasa
Year and Model: 740 2.3i
s80 2.5 T engine
Post by kielbasa »
Hi,
I couldn't find any specific info on this matter.
What's the actual difference between the 2.5T engine from an S60R and the 2.5T from an S80? I'm interested in the way it's built (internals), not the outside parts like oil filter location.
I'm considering buying an S80 in manual (3.0 t6 apparently didn't come with a manual transmission) and wanted to know if these S80 2.5 engines are as prone to cracking as the R version, and if they are easily modified too? What's the manual transmission limit on this model (torque-wise)?
I know there's a limitation since 2.5T manual versions came in the FWD only (correct me if I'm wrong), but it would be nice to hear any info on that too.
Thanks!
jasonbosch
Year and Model: 2016 XC70
Post by jasonbosch »
Hello,
In regard to engine internals, the S80 2.5T and S60R 2.5T share the same basic block and internals (open-deck 2.5L I5). The R is not reinforced internally; it just runs much higher boost and a bigger turbo, which is why Rs see more failures.
Moreover, S80 2.5T engines are far less prone to block cracking at stock or mild tune levels. Cracking is mainly a result of high boost/cylinder pressure, not a unique R block flaw.
In addition, S80 2.5T is fine for moderate tuning (roughly T5 levels). Pushing to R power or beyond without supporting mods increases cracking risk. Finally, Manual S80 2.5T is FWD only (you’re correct). Torque limit is roughly 350–400 Nm; clutch and gearbox usually fail before the engine.
