Did you know? 🤔
2010 XC70 A/C Receiver Drier Location
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
maverick455
Year and Model: 2010 XC70
Has thanked: 4 times
Been thanked: 0
United States of America
maverick455
Post by maverick455 » Tue Jul 30, 2019 7:18 am
I am trying to locate the Air Conditioning Receiver Drier on a 2010 XC70. I don't see it anywhere under the hood. Anyone know where it is located?
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 1 time
Been thanked: 5 times
Steve H
Re: 2010 XC70 A/C Receiver Drier Location
Post by Steve H » Tue Jul 30, 2019 12:29 pm
Inside a tube portion of the AC condenser.
These users thanked the author Steve H for the post:
maverick455
maverick455
Been thanked: 0
maverick455
Post by maverick455 » Tue Jul 30, 2019 8:16 pm
Thank you for replying. So the whole condenser must be replaced?
jimmy57
Been thanked: 237 times
jimmy57
Post by jimmy57 » Tue Jul 30, 2019 8:54 pm
No, the drier is serviced with a kit with desiccant insert and o ring to seal the access plug.
I have used the Four Seasons one from Rock Auto and from local auto store.
These users thanked the author jimmy57 for the post:
maverick455
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 23 times
Been thanked: 42 times
pgill
Post by pgill » Wed Jul 31, 2019 10:10 am
For my 2010 S80 3.2 the dryer is a desiccant bag inside the condenser.
It comes in a sealed aluminium Mylar bag and it only has a 1 year shelf life.
Don't open the Mylar Bag until you are ready to install the desiccant in the condenser.
The cap that holds the bag in place uses a Torx T-70 fastener.
I didn't check but I would think that the XC70 uses the same configuration
This is what I bought
GENUINE VOLVO 30776238 Receiver Drier Insert
If I had to do it again I would also replace the plastic cap with the O-rings and filter screen at the same time (I don't have the part number handy)
Note: to replace the desiccant bag you need to lift the radiator and Fan and then lower the cross-member under the radiator. This will expose the plastic cap with the T-70 that needs to be removed. Also don't forget to remove the R134a first.
Item #2 and #3
These are what I would replace
To remove the old bag you just need needle nose pliers or small fingers
The Bag fits inside the condenser, picture not to scale.
Good Luck
Paul
These users thanked the author pgill for the post:
maverick455
maverick455
Been thanked: 0
maverick455
Post by maverick455 » Wed Jul 31, 2019 11:47 am
I am replacing a bad compressor. When I purchased the new compressor, I also bought a Drier, but unfortunately got the wrong type (can type). I'm thinking since the compressor was bad, I probably should flush the system. I've read that the newer type condenser can't be flushed and should be replaced if the compressor goes bad . Any opinions on flushing the A/C system and the necessity of replacing the condenser on a Volvo would be appreciated.
pgill
pgill
Post by pgill » Thu Aug 01, 2019 2:31 pm
When I replaced the Compressor on my 2010 S80 I also replaced the desiccant bag because I read that a clogged desiccant bag can negatively affect performance of the AC system.
And I read about flushing the system but I decided not to.
But I did carefully follow the instructions on the compressor to spin the drive pulley so that the oil would circulate prior to use.
It works fine so far
Thanks
Paul
maverick455
