Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
2010 S80 3.2L Trans Urgent msg Topic is solved
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
MrBreeze
Year and Model: 2010 Volvo S80 3.2
Post by MrBreeze »
2010 S80 3.2L 99K miles
Throwing a service transmission urgent message on dash. Stuck in 3rd gear limp mode.
OBD shows P0700 Transmission Control System (MIL request)
EOBD shows P0965 Pressure Control Solenoid "B" Control circuit range/performance.
Cleared code and it immediately came back.
Anyone had low fluid cause anything similar?
Could a swap of the actual solenoid be worth a shot?
point me in the right direction please
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 40 times
Been thanked: 64 times
Post by xHeart »
Can you explain "IMMEDIATELY"?
When was the last ATF change?
Are you reading from VIDA DiCE?
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
MrBreeze
Post by MrBreeze »
immediately meant 3 seconds after next start up cycle after clearing the code.
P0965 was from a Sollus Edge reader ($5000) not vida dice
No previous ATF change (99k miles), and my Volvo tech says the dealership trashed their ATF machine because it created more problems than it was worth, and he doesn't recommend changing it.
xHeart
Post by xHeart »
MrBreeze wrote: Tue Aug 27, 2019 4:37 am immediately meant 3 seconds after next start up cycle after clearing the code.
Unless someone says otherwise, 3-second detection is an electrical issue.
Start with changing fluid and set the level -- use Volvo specified fluid.
MrBreeze
Post by MrBreeze »
So on a whim, I took my code reader to the S80 again, to verify the 3 second delay. Showed the P0700 MIL request again, cleared it, and lo & behold the Trans warning is gone. Have driven about 4 miles on a test drive to see if it would come back, not yet.
Wanted to know is there a way to ADD some trans fluid? Going to to attempt to get a reading on the fluid level as well. Thinking if the pressure solenoid threw the code, it may be low on fluid? Not going to drive too much until I have this info.
MrBreeze
Post by MrBreeze »
Drove this car for 250 miles and no issues. Maybe some dirt or debris in the trans fluid got stuck around solenoid? Just a weird random code? Sold at auction and moving on.
