Did you know? 🤔
2007 S80 3.2 Auto FWD -- Engine Air Cleaner Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 9 times
Been thanked: 49 times
United States of America
E Showell
Post by E Showell » Mon Sep 30, 2019 5:52 am
While changing oil yesterday, I noticed a gap in the air cleaner box in my wife's car, probably sufficient to allow unfiltered air into the engine. It seems like one of the holes for the torx headed screws/bolts that hold the lid on is stripped.
Anybody else experience this?
I am thinking I could drill through and just get a long bolt and put a nut on it to hold the lid down, or replace with junkyard unit if available.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
pbierre
Year and Model: T6 XC70s: '13 & '15
Has thanked: 0
pbierre
Re: 2007 S80 3.2 Auto FWD -- Engine Air Cleaner
Post by pbierre » Mon Sep 30, 2019 6:01 pm
Be thinking about passing smog test with whatever repair you do. The air cleaner box costs about $180, and is very easy to replace.
If the smog inspector sees a DIY repair, they will usually flag it (part of visual inspection).
E Showell
E Showell
Post by E Showell » Mon Sep 30, 2019 7:35 pm
In NJ, they don't even open the hood for inspection.
Has thanked: 252 times
Been thanked: 809 times
Trinidad & Tobago
Post by abscate » Tue Oct 01, 2019 9:14 am
beat drum.......
zip tie zip tie zip tie
Link To Volvo Glossary
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 1 time
Been thanked: 5 times
Steve H
Post by Steve H » Tue Oct 01, 2019 11:32 am
air filter boxes on these are pure JUNK. Not to have a metal inserted threaded hole in the bottom section should be criminal. Not selling just the bottom failing section should be tantamount to fraud.
E Showell
E Showell
Post by E Showell » Tue Oct 01, 2019 11:53 am
How difficult would it be to find a threaded insert and jb weld same in place after boring out holes? Although I like my longer bolt with nut after boring out hole solution as well.
Steve H
Has thanked: 1 time
Steve H
Post by Steve H » Tue Oct 01, 2019 11:59 am
The lower section is made of the most fragile plastic known to mankind. If you drop it because you handled it by the cool air snorkel and the snorkel falls out and it hits the ground it will split open. Guess how I know that? The sad part is that was my replacement part that this happened to after the original split all the screw holes it had.
E Showell
E Showell
Post by E Showell » Tue Oct 01, 2019 12:46 pm
Steve H -- Now tell me how you really feel.
Steve H
Has thanked: 1 time
Steve H
Post by Steve H » Tue Oct 01, 2019 12:50 pm
Yep, frustrating to buy such an expensive part as the entire air filter assembly and it be made out of plastic that is sub-par to any injected molded plastic that you would find at your local Dollar Tree store. Also to see no corrective engineering changes to address this problem between the original part and a part purchased 10 years later is also a problem.
E Showell
E Showell
Re: 2007 S80 3.2 Auto FWD -- Engine Air Cleaner  Topic is solved
Post by E Showell » Tue Oct 15, 2019 8:19 am
Mechanic put some longer and ever-so-slightly larger diameter self-tapping screws in. Problem solved.
