IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
1995 850 t5-R
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
polskamafia mjl
Has thanked: 7 times
Been thanked: 6 times
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu Nov 19, 2015 2:49 pm
November 18, 2015 - 277,785miles
Replaced voltage regulator
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sun Jan 10, 2016 1:34 pm
January 10, 2016 - 278,516miles
Oil change with ~6.5 qts Mobil 1 5w30 synthetic
Mann oil filter
Replaced drain plug with magnetic plug
New gasket on plug
Inspection performed at Your Inspection Connection on January 9
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 2 times
Been thanked: 13 times
Canada
mecheng
Re: 1995 850 t5-R
Post by mecheng » Mon Jan 11, 2016 6:54 am
You might make it to 300,000! Is it the original engine/trans/head?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sat Jan 30, 2016 6:49 pm
mecheng wrote:You might make it to 300,000! Is it the original engine/trans/head?
Original engine as far as I know (the previous owner did not have any service records for the car unfortunately) but I replaced the transmission with an M56 this past summer. Hopefully I hit 300K :D I'm trying to decide if I should keep working on the car at that point or if I should start looking for a new ride.
January 13, 2016 - 278,XXXmiles
Car in long term storage while I'm out of the country until May
Fuel stabilizer in gas tank
Battery removed
Wheels chocked, e-brake off
And I'm enjoying the Caribbean! :D
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Tue Jul 26, 2016 6:12 pm
June 2016
Replaced blower motor
July 26, 2016 - 281,143miles
Tire rotation
Noticed excessive wear on inner edges of all 4 tires
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Wed Jul 27, 2016 7:22 pm
July 27, 2016 - 281,143miles
Replaced brake booster check valve
Replaced front driver side turn signal bulb and cleaned electrical contacts to eliminate fast turn signal blinking
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu Jul 28, 2016 2:24 pm
July 28, 2016 - 281,185miles
AC system recharged and low pressure side schrader valve replaced at VIOC
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu Aug 04, 2016 4:52 pm
August 4, 2016 - 281,373miles
Replaced control arms, end links, steering rack bellows, and inner and outer tie rods with Meyle HD kit from FCP
Alignment performed at Swedish Motors, INC
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Fri Aug 05, 2016 6:26 pm
August 5, 2016 - 281,400miles
Replaced both front head light bulbs with 9006 bulbs
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Aug 15, 2016 7:40 pm
August 15, 2016 - 281,667miles
Oil change with 6 quarts of Shell Rotella T6 Synthetic 5W40
New Mann filter
New crush washer on drain plug
Gathered oil sample for oil analyses at Blackstone Laboratories
