IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
1996 850 Turbo, Red,
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Rbaratt
Year and Model: 850,S70,C70
Has thanked: 0
Been thanked: 0
Rbaratt
Re: 1996 850 Turbo, Red,
Post by Rbaratt » Mon May 19, 2014 8:12 pm
5/19/2014 - replaced fuel and air filter. Bosch fuel filter and Mann air filter.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Tue May 20, 2014 6:49 pm
5/20/2014 - muffler shop welded in new pipe with o2 bung between cat and muffler. Replaced rear o2 sensor with new Bosch sensor. Performed hard reset to ECU.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Fri May 23, 2014 7:08 pm
5/22/2014 - Glove box would not open. I tried unsuccessfully to fabricate a tool similar to the one the tech offers on youtube for $40 to jimmy the latch. Finally opted for the hack saw method that Ozark Lee described. Replaced all glove box hardware with donor parts from pick and pull. Turned out well except for some minor scuff marks on the dash pad.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Tue Jun 10, 2014 6:24 am
6-10-2014, Park brake adjustment issue - Shoes binding during and after adjusting, R/R shoe retaining clips and adjuster springs. Oiled cable linkages. No kinks or cracks noted on the cables. Shoes adjusted without binding. Will re-adjust in a couple of weeks.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Tue Jun 24, 2014 10:16 pm
6/25/14 - re-assembled turbo central band clamp with new stainless steel fastener.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Sun Jul 13, 2014 11:23 pm
7/13/2014, removed Volvo intermittent wiper delay relay and replaced with the VW "99" relay.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Thu Sep 11, 2014 12:44 pm
9-11-2014, R/R Windshield with Saint Gobain Sekurit glass - $185 installed. I believe that Pilkington is the OEM brand for the 850/S70 models.
Installed S70 style side trim strips with the rain channel. Thanks to RSPI for that suggestion.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Sun Nov 23, 2014 9:10 pm
11/22/2014 - R/R battery. $100
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Tue Dec 16, 2014 4:09 am
12/5/2014 - Purchased 4 new 16" Volvo steel rims. Dealer mounted and balanced 4 studded snows. Bad shake like a bent rim. Returned to dealer, they hammered the damaged rim and put the tire on the rear. This just masked the problem, as it is much better, but the shake is still there. Dealer ordering a new rim. I was pleasantly surprised as I figured they wouldn't warranty it saying I must have hit a pot hole or something.
Rbaratt
Has thanked: 0
Been thanked: 0
Rbaratt
Post by Rbaratt » Mon Oct 12, 2015 9:50 pm
R/R right wheel bearing Assy with FAG part from FCP. R/R control arm with Meyle part from FCP. R/R stabilizer rod with Lemforder part from FCP.
