Did you know? 🤔
VIDA 2014D Communication Tool Error
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
CamZH
Year and Model: '94 850 + '04 S60 R
Has thanked: 0
Been thanked: 0
Australia
CamZH
Post by CamZH » Sat Mar 23, 2019 11:54 pm
Hi Guys,
Having some issues with Vida.
I'm not able to select a Communications Tool (DICE)
I've seen its a common problem, but the registry edit suggestions didnt work for me (the entry was already there)
Win 7 Pro (64bit)
IE 11
.net framework 4.5.2 (rolled back from 4.7.2)
Anyone have any ideas ?
cheers,
2004, S60R
1994, 850 T-5 Wagon
CanadianSteel
Year and Model: 2001 V70XC
Has thanked: 0
Canada
CanadianSteel
Re: VIDA 2014D Communication Tool Error
Post by CanadianSteel » Tue May 14, 2019 6:35 pm
Hey Cam,
I am having the same issue. The communication tool is completely blank with a red X. I have rolled back to framework 4.0 with no luck. If you find anything let us know.
CanadianSteel
Has thanked: 0
Canada
CanadianSteel
Post by CanadianSteel » Tue May 14, 2019 7:17 pm
Hey Cam,
Just wanted to update you that I have fixed my issue. And for anyone else with this issue here you go for windows 7 64.
Hold windows key + R. Type regedit. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework
Once there click on the .NETFramework file and you will see 2 values (Default) and InstallRoot. There should be a 3rd value.
Right click .NetFramework than go to new and down to DWord (32bit) and click it. Name the new one "EnableIEHosting" without the quotations. Than right click the item you just renamed and click modify. In the value type "00000001" without quotations. Should be seven 0s and a 1. Click ok.
Congrats. Relaunch the webpage login and you should be able to pick your tool.
CamZH
Has thanked: 0
Been thanked: 0
Australia
CamZH
Post by CamZH » Tue May 14, 2019 7:54 pm
Thanks for the suggestion,
What's worked for you seems to be a rather common issue.
I've got the registry entry there, but still no dice. (pun intended)
2004, S60R
1994, 850 T-5 Wagon
RickHaleParker
Has thanked: 3 times
Been thanked: 409 times
United States of America
RickHaleParker
Post by RickHaleParker » Wed May 15, 2019 8:09 am
Vida DVD:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems,
xxx =x86 is for 32bit operating systems
Reboot and login.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
CamZH
Has thanked: 0
Been thanked: 0
Australia
CamZH
Post by CamZH » Wed May 15, 2019 6:16 pm
yep, I know this is the normal issue.
But its not my issue.
I'm going to attempt to re-format my machine and start again.
I have a feeling Windows updates have caused something that it doesnt like.
2004, S60R
1994, 850 T-5 Wagon
wizechatmgr
Has thanked: 22 times
Been thanked: 53 times
wizechatmgr
Post by wizechatmgr » Mon Aug 12, 2019 10:44 am
Glad I just read this thread. Had an unhappy camper after windows 10 fresh install. Appears to have done the trick!
1999 V70 XC AWD - ~183k miles
JoseBQ
Year and Model: 2009 XC60
Has thanked: 0
Been thanked: 0
Spain
JoseBQ
Post by JoseBQ » Wed Sep 18, 2019 10:18 am
Thanks, I solved my problem thanks to this thread.
