WHY - Vida Comm Tool Error Topic is solved
laser
Year and Model: 2001 V40
Post by laser »
WHY - Lost "Dice-206751" Communication Tool
After Login, user chose "Define Vehicle Profile"
But there is no Communication Tool to chose, only a red cross.
OK - Dice Hardware show as ok in Computer Management
OK - Green led is blinking on black hardware box with USB cable
OK - Green icon show up at bottom and then launch "Vida All in one"
Volvo S40 2002
Vida Dice 2013d
I used it for 18 month ago and there was no problem, same car and same computer and same software, the only new installed program is "Autocad" and "BMW scanner"
What can be the problem ?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Something messed with the Registration. This happens from time to time with a Windows update.
Solution:
Vida DVD:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems,
xxx =x86 is for 32bit operating systems
Reboot and login.
Active
Past
laser
Post by laser »
Now Vida Dice is working after some updates.
Installed IE9 32bit as recommended
Updated reg files after I found out that Laptop had .NET version 4.5 and greater
viewtopic.php?f=40&t=78173
Thanks "RickHaleParker" for your suggestions.
RickHaleParker
laser wrote: 23 Oct 2019, 09:24 Now Vida Dice is working after some updates.
Get the 2014D_RePack. It works with IE11 32 or 64bit and with .NET version 4.5 installed. No VM required. Lots of headaches out the window.
Active
Past
ratlinebrain
Year and Model: Volvo XC60
Post by ratlinebrain »
RickHaleParker wrote: 23 Oct 2019, 11:47
Get the 2014D_RePack eggy car. It works with IE11 32 or 64bit and with .NET version 4.5 installed. No VM required. Lots of headaches out the window.
It works for me. Thanks!
GwenSimmons
Year and Model: XC90 2005
Post by GwenSimmons »
Your VIDA software may not be detecting the DiCE tool due to driver issues or conflicts with recently installed software. Try reinstalling the DiCE drivers and ensure no other programs (like AutoCAD or BMW Scanner) are interfering. Also, check if the DiCE Diagnostic Tool recognizes the device.
schoolboy runaway
In this exciting sandbox game, players must collect resources and craft tools to survive. The game challenges players to think strategically while exploring new areas and facing various threats in different biomes. With new obstacles emerging frequently, Miniblox ensures that no two playthroughs are ever the same. Creativity and adaptability are essential as players shape the world around them and take on challenges that test their skills.
