Did you know? 🤔
xiaotec "850 OBD-II" Android app on Google Play for '96-'98 850/S70/etc
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
Geevs
Year and Model:
Has thanked: 0
Been thanked: 0
Geevs
Re: xiaotec "850 OBD-II" Android app on Google Play for '96-'98 850/S70/etc
Post by Geevs » Fri May 03, 2019 12:19 pm
Hi, I also purchased the latest version of the app (April 11, 2019) and it doesn't connect or scan anything. In comparison, Torque Lite and Car Scanner (both Android apps) work fine on the same device and BAFX BT ELM327 adapter.
The app's bluetooth screen, it shows my OBDII device as "in use", so I assume that the app has connected to it. However, the scan, connect and play/start buttons in various sections of the app don't work or respond as expected.
Can anyone give advice on how they managed to make the app connect with their BT adapter and get a meaningful response? I'm trying get the stored mileage on the odometer.
Thanks!
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 16 times
Been thanked: 17 times
United States of America
esl_97_850_T5
Post by esl_97_850_T5 » Fri May 03, 2019 3:24 pm
In "850 OBD-II" app, the "in use" description on the Bluetooth page seems to really mean "last paired Bluetooth device" (I think). In my experience, it definitely does **not** mean "connected". [Maybe item 3 below will help shed some light -- Easiest way to connect is to press triangle icon between Info icon and Bluetooth icon, then wait a few seconds.]
I've used BAFX BT with both V1.1.6 (2019-01-03) and V1.2.7 (2019-04-11) of "850 OBD-II".
I've also used OBDlink MX+ with "850 OBD-II" V1.2.7 (2019-04-11) using the factory v4.5.12 firmware that came with the OBDLink MX+.
1. What kind of vehicle are you scanning?
What kind of phone are you using?
What version of Android are you running?
2. Today, I used my BAFX with "850 OBD-II" V1.2.7 (2019-04-11). It worked without jumping through any hoops. [I changed my Bluetooth device from whatever string represented the OBDLink MX+ to the "OBDII" device. I actually pressed it twice. Once, which exited the Bluetooth page, then I entered the Bluetooth page again and saw "OBDII" device was "in use", then pressed that device's description again.]
3. Here's a short summary of what I did...
After selecting the "OBDII" (ie, in your case BAFX) device using "850 OBD-II" app's Settings / Bluetooth function, and seeing it is "in use", then return (via your phone's Back button) to the screen that shows the line "Live / Service / Settings" at the bottom. Now at the top of that page, press the right-facing triangle that is between the circle-i (Info) icon and the Bluetooth icon. Wait a few seconds for the uncolored right-facing triangle to become two green vertical bars that indicate "your BAFX is connected". Then click the Service button at the bottom center of that screen. Then click the Scan button at the bottom left of the Service screen. Wait several minutes for the Scan to finish -- during which time commands/requests and their responses should be near continuously be appearing and scrolling off the display. Then click OK, click Back, and hopefully you are back at the Summary page.
4. If that doesn't get you up and running, I can post a much more detailed list of the steps I followed. But I'm guessing that "pressing the triangle button" is the hint that you needed -- since I also had to have the developer clue me in to connect that way.
5. By the way, my phone runs Android 5.1. I believe the "850 OBD-II" app's Info page explains the app's required minimum Android version. If you have a very recent Android version, maybe the app doesn't yet run with that, and you'll need to email the author to get the app running on your phone.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
RickHaleParker
Has thanked: 3 times
Been thanked: 562 times
RickHaleParker
Post by RickHaleParker » Fri May 03, 2019 3:42 pm
The bluetooth connection is buggy. Shut down all other apps that use that connection. Delete the bluetooth pairing. Reboot the phone. Then try pairing 850 OBD-II to the ELM327.
Another option is to use install NOX Android Emulator on a PC or a Mac and run 850 OBD-II isolated from the other OBD-II software. You can run 850 OBD-II on multiple devices if they are connected to the same Google account.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
Geevs
Year and Model:
Has thanked: 0
Been thanked: 0
Geevs
Post by Geevs » Mon May 06, 2019 10:45 am
Hi all,
I have tried all suggestion from this forum and also from the app developer who responded to my email. I tried the suggestions on 2 phones and 1 tablet and the app still won't work. However, other apps like Torque and Car Scanner continue to work.
Interesting, this app messed up one of my phones causing it not to boot up. Fortunately, this was on a backup phone running Android Pie. Now I wonder if this app is a rogue app with malware in it.
I've unisntalled the app from all my devices.
BTW, I'm running the latest version 1.2.7 released on April 11, 2019.
Cheers,
Geevs
Geevs
Year and Model:
Has thanked: 0
Been thanked: 0
Geevs
Post by Geevs » Tue May 07, 2019 10:56 am
Hi all,
I've been emailing the app developer and he says his working on improving the BT connectivity of his app and plans to release an updated version soon.
In the meantime, I was able to obtain the mileage of my 850s using a Linux-based python script (mentioned one of the other threads in this forum) and a BT ELM327 adapter.
Question now is - after I replace the broken odometer gear in the cluster, how does one update the odometer itself to match the mileage stored in the cluster?
Thanks!
esl_97_850_T5
esl_97_850_T5
Post by esl_97_850_T5 » Sat Aug 10, 2019 1:00 pm
That is a YouTube video that MVS's rspi did in early 2019 showing the quickest way to read the '96-'97 850 mileage from VDO clusters using "850 OBD-II" Android app V1.1.6. The method also works for the '97-'98 S70/V70/C70/XC70 Yazaki clusters.
Thank you, Robert!
esl_97_850_T5
esl_97_850_T5
Post by esl_97_850_T5 » Sat Aug 10, 2019 1:50 pm
In response to a post in another MVS thread, I thought it best to put this info here in this thread dedicated to "850 OBD-II"...
The "850 OBD-II" Android app was developed by Aleksi Venäläinen from Finland.
He used some 850 info at jonesrh.info's Volvo 850 OBDII portal to develop an "850 OBD-II" beta version. Once I saw he was serious, I gave him the internals of the jonesrh KWPD3B0 interpreter that deal with interpreting the raw DTC codes that translate to the 3-digit Volvo DTC codes like:
- CI-221 -- Vehicle Speed signal missing [usually due to bad ABS module solders]
- ABS-311 -- Left Front Wheel Sensor, open/short [or bad ABS module solders or ignition switch]
etc. From there, he kept adding facilities.
Now -- as of the "850 OBD-II" V1.2.9 [2019-06-07] release -- there are several ways that the "850 OBD-II" app has surpassed even the recent volvo850diag v0.9 [2019-07-14] release:
1. "850 OBD-II" app can perform realtime interpretation of the data it receives from the '96-'97 850 and '97-'98 S70/V70/C70/XC70 !!!
volvo850diag, on the other hand, is a relatively "dumb" program in the sense that it does *NOT* interpret the data from the car. Instead, the data is logged, then (as of 2019-08-10) it must afterwards be interpreted by submitting to the jonesrh KWPD3B0 interpreter page.
2. The latest (as of 2019-08-10) "850 OBD-II" app V1.2.9 scans several more ECUs -- eg, the ones specific to the C70 -- compared to the latest (as of 2019-08-10) volvo850diag v0.9 version.
3. Even though "850 OBD-II" app originally used the 2 hex digit raw DTC <-> 3 decimal digit Volvo-specific DTC codes association provided by jonesrh, the most recent versions of "850 OBD-II" app includes more DTC data for more ECUs, and the app includes much better raw DTC to 3-digit Volvo DTC associations for AW 50-42 (ECU 6E) DTCs -- compared to what jonesrh KWPD3B0 interpreter does.
4. The latest (as of 2019-08-10) "850 OBD-II" app V1.2.9 can perform testing of components in MSA 15.7 (ECU 11), AW 50-42 (ECU 6E), and ABS (ECU 01). That's something that volvo850diag v0.9 can *not* do.
5. "850 OBD-II" performs Live data scanning of individual ECUs much faster than volvo850diag.
Aleksi (or his company) is known as xiaotec on the Google Play xiaotec "850 OBD-II" page.
He has (or had) a presence other places on the net as XantheFIN.
He has introduced himself to the MVS community as "xanthefin" in the thread
viewtopic.php?f=1&t=89530 and in a few other MVS posts.
esl_97_850_T5
jonesrh
bricklurv
Year and Model: 740 1989
Has thanked: 4 times
Been thanked: 0
Australia
bricklurv
Post by bricklurv » Sat Sep 28, 2019 4:05 am
I just bought the App and an ELM 2.1 to upgrade my older ELM bluetooth and will give it a whirl on my 97 850SE, my 98 S90 and see how it goes on my 01 S80 when it arrives.
Any advantages on the later ELM units? the old one works fine with the MY00 Hyundai and Torque Pro but I thought id hedge my bets and buy a later chip version ELM unit.
89 740 Wagon
88 740T HP
97 850
99 V40T
99 S90 (Last of the RWD)
01 S80 2.9
73-77 W116 D and K jet Mercedes
73 C107 D jet 350SLC Mercedes
71 Chrysler Valiants x 2
83/84/86 Range Rovers x 3
And....... A Mini
xanthefin
Year and Model: 1997 850
Has thanked: 1 time
Been thanked: 5 times
Finland
xanthefin
Post by xanthefin » Sat Sep 28, 2019 11:54 am
Hi! I would say that later versions does enhance greatly newer CAN bus system cars so in Volvos thats 1999 and forward by adding some command sets and buffer size and some stability. As for app this is mostly for 98 and below Volvos in many ways (at moment still..).
Here is as shortly but directly what differences there is.
One look i took was AMC command..
“The Activity Monitor uses a counter to determine just how active the ELM327's OBD inputs are. Every time that activity is detected, this counter is reset, while if there is no activity, the count goes up (every 0.655 seconds). This count then represents the time since activity was last detected, and may be useful when writing your own logic based on OBD activity. The counter will not increment past FF (internal logic stops it there), and stays at 00 while monitoring.”
Which sounds interesting as itself IF it could be used for Fenix 5.2 ECU example in very twisted way. But can't send command in other way which then makes it unusable..
And all this is for genuine V2.1 or which really has V2.1 command set included.
For the app i am not taking any advantage yet of CAN system in any special way. Only push start was earlier include VIN reading in Basic OBDII scanning if there is support one like i believe in 2016 Volvos i believe.. after with testing one coworker's CAN only car verified it working.
I am listening always feedback and taking look into things which can be possible as i am interested and will continue be still (thats includes CAN Volvos too in future as i get hold myself one). Thanks everyone! Specially Jonesrh being supportive. As i am kinda made myself busy with all. I am maybe not so active on forums. But i want be open person.
IF i didn't answer at your question anything useful.. sorry i do that often. Let me know and i try fix that bug. :mrgreen:
These users thanked the author xanthefin for the post:
bricklurv
bricklurv
Been thanked: 0
Australia
bricklurv
Post by bricklurv » Sun Sep 29, 2019 2:54 am
89 740 Wagon
88 740T HP
97 850
99 V40T
01 S80 2.9
And....... A Mini
