IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Object doesn't support property or method 'DiagnosticAllowed' vida 2014D
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
Kazthebassman
Year and Model: C70 1999
Has thanked: 2 times
Post by Kazthebassman »
VIDA 2014D . I am using Win 7 Pro 64 bit 3.8G mem. Nearly new install. One small audio interface program added.
All vehicle profile info is entered.
The diagnostics tab is 'greyed' .
Communication tool box- has an "x" in the top right corner. No selections are able, to be made.
I get ( object does not support method or 'DiagnosticAllowed' ) after entering vehicle information.
Dice did connect to computer with external power supply and USB. Tests OK with Dice program diagnostic,
other than the 'interface test' as that seems to require some sort of test connector. Firmware 5.6.2 .Hardware Ver. 1.4.3 .
Dice is not connected to any vehicle at this time.
software tab opens and says "Software Download Manager failed to load..."
Other tabs (information, work list) seem to work ok.
Any help with getting this functional would be great. Thanks
Kazthebassman
Re: Object doesn't support property or method 'DiagnosticAllowed' vida 2014D
This particular problem with my particular program(2014D), may have been Java plugin not enabled/installed.
Be sure sure you have updated your Patch license text to a future date or you will never be able to log in.
I used a new install of Win 7 pro. No updates. Removed IE11. Installed IE 9. Installed latest Java.
Installed Patch file with Vida running in tray (green Arrow). Restart. Click on "All in One". Enabled plugins, just prior to login, through pop up. Login in as 'admin' or '1'.
RickHaleParker
Has thanked: 3 times
Been thanked: 616 times
Post by RickHaleParker »
My Google Chrome conversion gets around the issues (Vida and Dice) vs (IE11 and .Net Framework 4.5 or higher) in Windows 7.
Chrome conversion: viewtopic.php?f=40&t=83998
2004 S60R, B8444S TF80 AWD.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 21 times
Been thanked: 20 times
Post by XC70Rider »
I cannot get Diagnostics to work on VIDA. I installed VIDA on a laptop with windows10 using IE11.
When using IE11 I get this error message after selecting my vehicle:
OBJECT DOESN'T SUPPORT PROPERTY OR METHOD DIAGNOSTICALLOWED
I added the IE tab to Google but still cannot connect to Diagnostics. Here's the error when opening VIDA with Google Chrome:
getCommToolSettingObject(...).DiagnosticAllowed is not a function
I added the patch again and reboot but still cannot get Diagnostic to function with IE11 nor Chrome?
Kazthebassman
Win 7 Pro only, for my version. Win 10 is totally different. If your version wasn't designed for Win 10, you may need to change your operating system or search the net for Win 10 info on this. The good news is Win 7 Pro is available cheap. A clean hard drive with no previous failed installs is a good idea too. I was painful and took very many hours/days, to get mine correct. My post above may or may not help you but I'd take a serious look at it.
XC70Rider
Post by XC70Rider »
2014D can be installed on WIN10. I had it installed on my other laptop with same operating system.
The problem was with JAVA. Did a clean re-install now I cannot login. Problem now is the patch not working.
Kazthebassman
"Be sure sure you have updated your Patch license text to a future date or you will never be able to log in." Have you done this? It MUST be done. I believe it is in a text file within the patch. If the date is a past date, just change the date to a future date. You may need to remove the program and possibly the OS and reinstall everything, if it still does not work. I know it's all time consuming and frustrating but expect it to be..it seems these always are.
deano1
Year and Model: 2003 s60, 2003 C70
Been thanked: 2 times
Post by deano1 »
I had my windows 7 pro laptop loaded but had the black "x" of death where communication tool was supposed to be. Follow this video it worked for me.
Cheers
