Iridium Spark Plugs
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
sammyS40
Year and Model: S40 2007
Iridium Spark Plugs
Post by sammyS40 »
I am considering upgrading my 2007 S40 to iridium spark plugs from OEM. Will iridium plugs help performance? I have heard rumors that upgrading plugs will make your car run rough. What is the truth?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Stick with the stock plugs. Volvo does a very good job of picking the right plug as stock.
Retired
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Avoid iridium plugs at all cost.
Ambitious but rubbish
sammyS40
Post by sammyS40 »
Thanks guys. I'll stick with the OEM spark plugs.
Sammy
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
The stock ones are better and sometimes the copper does just as well if not better. Just have to change it out more frequently as the tip is not as hard and wear quicker. Check for Heat Range as some allow for different heat range plugs depending on driving conditions/style. I have seen Platinum's go 100,000 miles and the car still does not run rough but after changing them the car runs much quieter and faster with improved mileage. Iridiums, not sure the expense justifies any potential benefits?
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
I ran iridium plugs one time on my old NA s70 and did not have any problems, but I wasn't paying attention to gas mileage. They did last a long time.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Beck
Year and Model: 04 V70 2.5T AWD
Post by Beck »
I ran them last plug change. As long as your gap I correct the plugs will run fine.
nzvlnr
Year and Model: 1999 s70t5
Post by nzvlnr »
I am changing my plugs...(99 s70 t5) and in the #1 cylinder there was oil , the top of the head was clean...clean....
The spark plug did feel loose. I am chalking it up to that....and ideas?
What is the gap on the stock volvo plugs?
