VS M4.4 tuning dead? Start again here?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
xnRS
Year and Model: 1994 Volvo 850 2.5T5
Has thanked: 7 times
Been thanked: 5 times
Re: VS M4.4 tuning dead? Start again here?
Post by xnRS »
S23 wrote: 09 Nov 2025, 09:35 Has anyone installed a live eprom editing emulator? E.g. Moates Ostrich 2.0 or Cobra RT?
There is info about installing it on m44 wiki
Considering the price of Ostrich and Cobra emulators, IMHO it's kinda pointless...
1994 Volvo 850 T5
Italian spec, originaly 2.0 T5, early facelift with OEM RIP kit, early dash buttons and etc.
Previous Owners swapped 97' B5254T
Mods: Titan R17 Rims, Japanifold, Motronic 4.4 with S70R Tune
A1304
Year and Model: S 70 T5 1998
Post by A1304 »
Hello everyone
After installing the broadband controller, I noticed that at 1700 and 2300 rpm, the mixture becomes poor up to 15-16 afr, sometimes a detonation is registered after that. If anyone has encountered such a problem, can you tell me how to solve it?
AFR
AFR
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
A1304 wrote: 25 Nov 2025, 04:25 Hello everyone
After installing the broadband controller, I noticed that at 1700 and 2300 rpm, the mixture becomes poor up to 15-16 afr, sometimes a detonation is registered after that. If anyone has encountered such a problem, can you tell me how to solve it?1.jpg
We kind of need to know a bit more about the condition of the engine currently. What mods, etc.
A1304
Post by A1304 »
Green Injectors 440cc, 255 l/h Fuel Pump, 14POINT7 SLC Free 2 Wideband, Pressure sensor mpx4250d, Upgraded fuel pump wiring, The 'R' manifold.
A1304
Post by A1304 »
Turboforslund
Year and Model: SC Volvo 850 T5 -95
Post by Turboforslund »
xnRS wrote: 20 Nov 2025, 04:26
Hi,
I have done it! It is a perfect way of getting there quickly since it is live tuning, and best of all, more accurate for all your tweaks. I recommend it! 😉
A good way if you also plan to tune other cars with that ECU feature. When done, just flash that bin to a standard ECU.
Let me know what you need.
Send me a mail ([email protected]) if you want guidance, pictures, pinout etc.
// Turboforslund
xnRS
Post by xnRS »
Turboforslund wrote: 29 Nov 2025, 06:53
Hi,
// Turboforslund
Hi, my only concern is the price of Ostrich and CobraRTP emulators.
200USD is too much for just an emulator
1994 Volvo 850 T5
Chuck W
Post by Chuck W »
A1304 wrote: 27 Nov 2025, 23:40 Green Injectors 440cc, 255 l/h Fuel Pump, 14POINT7 SLC Free 2 Wideband, Pressure sensor mpx4250d, Upgraded fuel pump wiring, The 'R' manifold.
What loading is the engine under?
You have the ability to tweak your fuel settings, etc, so why not add a little bit in that zone?
A1304
Post by A1304 »
I added fuel in these places, it didn’t help, I’m trying to change the lambda regulation.
Chuck W
Post by Chuck W »
So, are you using VAST's WBO2 modulation bin?
Have you done the calibration with the 14point7 WBO2?
Where is your O2 sensor located?
It's been a minute since I've looked at the map in my modulated bin.
