Did you know? 🤔
Flashing check engine light after mods!
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
RyanT5
Year and Model: S70 T5, 98
Has thanked: 0
Been thanked: 0
RyanT5
Post by RyanT5 » Thu Feb 28, 2013 7:01 pm
So a couple days ago my ARD green tune came in for my s70 t5. The tune hasnt made much of a difference thus far because i do not yet have the catless 3" exhaust it was programmed for, and my tcv is old as ****. Tonight i made a MBC and installed it. The car hasnt boosted over 14 or so psi, but at wide open throttle im getting a flashing engine light and the car stumbled. The car does need new wires and a rotor. Am i overboosting or is the ignition system just not in good enough shape to handle the amount of boost its now running? Its a blast to drive, just a bit worried :?
Matty Moo
Year and Model: 850, 1996
Has thanked: 0
Been thanked: 14 times
United States of America
Matty Moo
Re: Flashing check engine light after mods!
Post by Matty Moo » Thu Feb 28, 2013 7:38 pm
You need to be at stage zero, 100%. Zero fault of the tune.
Proper plugs, good wires, cap, rotor, vac lines and pcv.
Why are you putting an mbc in with a tune?
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
RobTheModd
Year and Model: 98 S70M - 18 S60
Has thanked: 4 times
RobTheModd
Post by RobTheModd » Thu Feb 28, 2013 7:48 pm
Iirc flashing check engine means missfire.
Get your codes checked.
Mine does it from time to time usually due to one of the plug wires coming up a bit.
ARD-Lucky
Year and Model: 1994
Has thanked: 0
Been thanked: 0
ARD-Lucky
Post by ARD-Lucky » Thu Feb 28, 2013 9:56 pm
Yup, flashing CEL is misfire. Time for tune up!
