Volvo Turbo whiteblock white T5 Performance Parts big turbo
This topic is in the MVS Volvo Repair Database » Performance Whiteblock Parts for Sale - Turbo, Manifold, Block & More
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I have a bunch of whiteblock T5 performance parts. Most parts are for 850 turbo and early C70/S70/V70 turbo. Block and transmission are not in picture. Parts are located in Mesa, AZ 85204.
Rebuild 01 block with RSI rods, stock pistons, new rings, polished crank, new bearings, honed block
$1000
http://www.thelostartof.net/tryingbe/forsale/t5block/
98 M56H using internal slave cylinder.
$400
Picture on request.
Japanese manifold
$80
Rebuilt custom turbo with Volvo flange by AZ turbo. The compressor wheel is a T04B 60-1, AGP anti-surge compressor housing, single ball bearing, stage III turbine wheel, and a/r .63 turbine housing. BIG power can be made with this.
$650
ATP Ultimate waste gate, ceramic coated.
$150
ATF oil coolers, 3/8 hose in and out.
$10
URO throtle body hose
$5
Headlight cover
$10 for both
Upper Poly mount
$10
Black glove box cover
$10
Cabin air filter conversion kit for early 850.
$5
Tan glove box cover
$10
Arm rest.
$15
19T actuator. Holds vacuum just fine.
$40
98 Volvo Turbo T5 M4.4 ECU. Ready for tune it yourself.
SOLD
OBX Racing Sport Turbo Back Exhaust 94-04 Volvo 850 C70 S70 V70 T5 W/ Downpipe
FLAT FLANGE ONLY. Never used, never mounted.
SOLD
Used spec stage 3 clutch and pressure plate, comes with new threw-out bearing. I was told it was use a few thousands miles. Plenty of meat left. For single mass flywheel, 850/C70/S70/V70
SOLD
85 GLH, 367 whp
00 Insight, 72 mpg
