Where can I find a wiring harness for installing an aftermarkey stereo into a 2004 s40? After pulling the factory radio out, I found it has an external amp.
Or any info on wire colors/function would be great.
Radio/Amp Wiring Harness
Guest
have you tried here?
http://www.volvoclub.org.uk/information-sv40.htm
i havent tralled thru it but might be
Any way, you say it has a separate amp, i have a sub in the back of my V40 which i'd like to "tune" are ther any controlls on the amp or is it just inputs & outputs?
Cheers
Cheers
morrisamazon
Hi G:
Are you still looking for the plug/harness? I can supply you with these and also the radio mounting kit and antenna adapter needed. Let me know if you're interested.
Keep Kool
Keep Kool
