Noise from front left
shanegtr
- Year and Model: 1999 V40 2.0T
Hi all. Just thought I'd ask if anyone's had a similar issue to what I'm having now. During deceleration while turning(both directions, but most noticeably left) I get what sounds similar to a CV. Goes away when you get back on the accelerator. The sound is like a rub. I'm thinking the left front wheel bearing maybe on its way out. Any other thoughts worth looking at?
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Would a rotor not mounted flat against the hub result in steering wobbles similar to a wheel balancing issue?
A properly hub mounted rotor but with a warp in it might cause the rubbing sound and the disk runout you have noticed.
Also have you checked that the calliper assembly securing bolts are tight ?
