2001 V70 T5M Cruise Control Issues ME7
dux02v70
- Year and Model: V70 2002,V70T5M 2001
I've searched this forum and others regarding cruise control issues with manual cars and there is lots of discussions about the clutch position sensor. Typically, it seems that switch failures trigger a warning lamp on the dash. I have no warning light, just no cruise control. When I first start the car, if I push the cruise button it illuminates the CRUISE indicator on the dash but it then turns off soon after. I checked the codes using an autocomm cdp+ and it shows ECM 9300 Permanent Clutch Switch Failure or something to that effect. No signal too high or too low, just failure. If I reset the code it comes back as soon as I start the car. I pulled the switch and cleaned it with contact cleaner and it is showing variable resistance as I move it in and out. Does anybody know what the resistance range is for this switch? I don't mind replacing it if it is bad, I just don't want to spend $70 on a part if it isn't the problem.
- Been thanked: 4063 times
I don't have a pinout handy but here are the Ohm readings..on edit - found them
- Screen Shot 2015-11-09 at 1.30.48 PM.png (21.67 KiB) Viewed 2208 times
- ME7 Cruise control - clutch switch 7/123 pins 2,4 active
- Screen Shot 2015-11-09 at 1.33.14 PM.png (239.39 KiB) Viewed 2207 times
- Screen Shot 2015-11-09 at 1.34.42 PM.png (157.6 KiB) Viewed 2207 times
