2002 V70 x/c springs Topic is solved
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
Anyone out there tried the 2" lift springs available for the V70 X/C?. They replace the stock springs and add about 2" in height. I would be especially interested in clearance/ binding issues within the suspension. They still utilize the stock struts and shocks.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The handling/stability at speed wont like this, plus you may have camber issues causing uneven tire wear. My S60 got lifted from replacement shocks and ouch the change
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Why lift?
There are reenforced springs that keep geometry and handling stock (a tad stiffer in the rear perhaps) but also keep the car from sinking too low when loaded, if that's the issue.
Some lifting when replacing old and worn shocks and springs is to be expected regardless though. My V70 probably gained almost an inch. Now it looks like in the original marketing materials again rather than like it was lowered. Also handles loads better since it's not too squishy
