Mystery connectors from passenger dash 2012 S60 T5
Sherlock77
- Year and Model: 2012 S60 T5
Hi, I recently needed to partially pull the dash on my 2012 Volvo S60 T5 and have a couple of connectors in the glove box area which I cannot remember should connect to. One connector is grey with orange interior and the other is green. I have identified and reconnected the glove box wiring but the dash also gives an airbag indicator. Any insight will be helpful.
- Has thanked: 1834 times
- Been thanked: 1709 times
Did you reconnect the passenger airbag in the top of the dash? Does your car have knee airbags?
Hopefully you disconnected the battery when working on the dash as you can trip the airbags, and trip the SRS waring light.
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 155 times
- Been thanked: 141 times
In case it is similar to xc60.
Glove compartment: usually there would be 3 wiring connectors. 1-top left of the glove box connects to the memory card holder inside the glove box(I assume it is for maps), 2: top of the glove box illumination. 3 illumination for leg compartment under the glove box.
Hope helps
Hope helps
