Alarm Module 9452709 9452708 Replacement - Through the Headlight
Been thanked: 472 times
Re: Alarm Module 9452709 9452708 Replacement - Through the Headlight
Post by cn90 »
Also,
Not sure why anyone spends $377 on the alarm module.
"Nobody" steals these 20-yo cars lol.
PS: I spent time replacing the alarm battery on the 2004 V70, which was sold recently. I still have 2006 and 2007 S60s at home, if I ever have this issue ("alarm system needs servicing" etc) again, I will simply ignore it by pushing the button at the end of the turn signal stalk.
Has thanked: 1505 times
Been thanked: 3818 times
You don’t need to code the module to replace the siren, but if it is inop, you might not able to add keys. My Volvo dealer told me that back in 2014 when I keyed Catherine the 2005
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
abscate wrote: 13 Sep 2025, 14:29
Yeah in my house, deaf jokes are unheard of too.
Well done!
If you aren’t getting the service message on the dash, put checking Vida on the priority list below the monthly clocking of the tire fill stems
sirens are plug n play,
I've pulled 3 from the boneyard, through the wheel well is quicker for me, a dremel to remove the rivets works, then use the dremel to cut slot in the security bolt head, stubby screwdriver gets it loose to spin out by hand.
All the used ones I've pulled were toasted by acid. So I just leave it unplugged, it doesn't affect anything else.
