jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
CHARM online service manuals for volvo, it looks identical to vida but its quicker than hooking up ther laptop to the car. free.
https://charm.li/Volvo/
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Kära is 20 years old today so Brodie and I went out to Rouken Glen park this afternoon
This was Brodie 2 months ago
This was Brodie today
Rouken Glen.jpg (261.71 KiB) Viewed 460 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
IanDonkin
Year and Model: 2005 V70 2.5T SE Man
Post by IanDonkin »
Just back on the forum after many years away from V70 ownership (and glad to see that it's still active)... first job was to tie the rear exhaust silencer back up after the welded mount around the outlet pipe gave way due to corrosion; that was barely 14 hours after we acquired it for my 17 year old son!
New back box and middle silencer subsequently ordered - it looks like the failing one is the original so it's done very well to survive for 20 years. I'm sure there will be much more to come...
IanDonkin
Post by IanDonkin »
Following on from my exhaust exploits, it was the coolant pipe from the block to the top of the radiator next.
The PO said that it had a small coolant leak that he hadn't been able to trace; if he'd actually looked to the side of the radiator he might have seen the witness marks of coolant all the way down the side of it and the occasional drip from the hose. It transpired to be a very poorly fitted and the jubilee clamp was only holding 70% of the pipe; needless to say that is now addressed and we'll await the next early ownership experience (beyond it being comfortable and quite rapid).
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
Years and vibration caused that pin to drive up, the spring tilted the hinge, plastic broke. Pretty typical for Volvo.
Luckily, plastic is very easy to work with. All you need is a piece of 14 GA stainless sheet, plasma cutter, metal brake and a bit of Gorilla Heavy Duty Construction Adhesive. Fixed!
P80GLT
Post by P80GLT »
Kära is due the annual MOT test at the end of October so she was booked in this morning and happy to say she passed without and advisories
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1834 times
Been thanked: 1709 times
Did the tester dare to fail your car??
P80GLT
Post by P80GLT »
scot850 wrote: 01 Oct 2025, 08:31 Did the tester dare to fail your car??
It wasn't my usual MOT tester today, he was going to a funeral so I had the garage owner do the test. I've been going to the same garage for MOTs for 39 years and this is the first time the owner has tested my car.
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Now that is one loyal customer! It is great when you can find a repair shop like that you can rely on. I have a local shop I use and recommend here in Calgary for the reasons they are honest and reliable. Funnily enough it is owned by a fellow Scot ex-pat from Fife. He is now in semi-retirement and his son is now running the business. They are always busy.
P80GLT
Post by P80GLT »
Correct Neil. Before I found this MOT garage it was always hit or a miss as to whether the car was going to get a fair and honest test. Too many cowboys trying to pull a fast one to get the work repairing the car. I once put a car in for an MOT and called in the afternoon to be told it had failed on a burst brake pipe. I knew the pipes were fine when I left it there so I went in and drove it out using the handbrake. Upon inspection I could see the pipe hadn't broke from the test, it had been snipped with a pair of pliers or similar.
2010 XC90 SE...SOLD
2005 V70 2.5T SE
