Has thanked: 1497 times
Been thanked: 3809 times
What’s the Mercury doing in Calgary this time of year ?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
It's pretty typical pre Christmas weather.
Screen Shot 2025-12-20 at 5.19.31 AM.png (62.93 KiB) Viewed 304 times
2003 XC 70 (sold)
Has thanked: 1834 times
Been thanked: 1709 times
By the middle of next week it will almost be tropical up here! Year end we are being told (unlikely) that we may scrape above 0C! Heat wave.
The downside to the cold weather is it makes removing plastic parts really a waste of time at the junkyard as they just break. :cry:
Blacklab467
Installed some new foglights today to replace my smashed up old ones. I cheaped out and bought aftermarket brand from IPD, I think they were about $80 and seem to be very good quality. The brand is TYC and they have glass lenses and an height adjustment screw just like the Austrian originals. I couldn't bring myself to spend $250 each on the Volvo ones for a part like this.
2003 XC 70 (sold)
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
Today I attempted the AW55 backflush. I did manage to get some gunk out, but because of some technical errors on my part I couldn't repeat the backflush cycle more than once(I dropped the oil on the floor and made a mess).
In the oil however were small loose pieces of what I think was clutch pack material. Tomorrow morning it will become apparent if I managed to get enough material out of the filter. In any case, it was very easy to backflush, if I only I didnt drop the oil.
Blacklab467 wrote: 20 Dec 2025, 05:22 It's pretty typical pre Christmas weather.
Essentially 0F for those living below the Health Care Line
A bit nippy for outside car work
Georgeandkira
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
I reinstalled my repaired DIM to my 2007 V70 w/151.7k.
Every gauge, LED and message element went crazy.
Up Fix, in Georgia, did the repair.
Their website offered a special price of $299. It's usually triple that.
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
scot850 wrote: 20 Dec 2025, 16:19 By the middle of next week it will almost be tropical up here! Year end we are being told (unlikely) that we may scrape above 0C! Heat wave.
i use a portable heat gun on plastic parts when it gets too cold. Do your yards restrict something like that from going in?
Yes. No heat guns of any sort, no jacks, no sawsalls, no grinders. I understand their reasons to prevent fires, but it can be difficult with old cars when ou cannot use heat. I have had to bring home whole suspensions with the hubs attached so that I can heat them to separate and then take stuff back. Downside is returned items only get instore credit. Means I have to go back to use the credit up............ :lol:
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Finally had the XC70 back from the shop last week with it's new heater core... and an empty wallet now!
Not had the time to drive the car until this week, it's warm and cosy inside and everything feel tight.
It took them ages to fix it. The good, i could see some new parts free of charge, pipes for the heater core are new, the AC sensor under dash is new with a gaz refill and a new isolation foam, a good clean of the evaporator.
The bad, hand lever gaiter is crack open, gear lever gaiter worse than before, slight scratches on the lower dashboard, the steering wheel is not straight, two bulbs on the headlight switch out.
All in all happy to have my car back on the road :)
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
