I recently purchased one from the first eBay seller PN 39802015. The rubber piece is shaped hard plastic molded one piece with the panel. Perhaps it's stronger but not sure if it will scuff the seat belt overtime as I haven't installed it yet. The color is not exact as I didn't pull the broken piece for both the XC90 and S60 to check the PN. The second link is for a black cover and if the coupon is applied during check out it's $20.65.
$23.00 39802015 Front Left Seat Side Switch Panel Trim For 07-14 Volvo S80 XC90 V70 S60
https://www.ebay.com/itm/286786046551?f ... HDGBB57N3Z
($20.65 with coupon code) Left Driver Seat Side Switch Panel Trim Cover 39802011 FOR Volvo S80 XC90 V70
https://www.ebay.com/itm/187523102110?f ... R4rdnu2QZw
Left Seat Switch Panel 07-14 Volvo XC90 S80 V70 S60
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
- Has thanked: 1834 times
- Been thanked: 1709 times
Can you sand the edge of the seatbelt slot to remove any rough surface? Another option would be to use some of the 'U' shaped plastic that is used to save door or panel edges from chipping and fit it between the panel and the seat belt.
- MoVolvos
Since you asked I had to take a closer look
Well that is good news! No need for us to worry.
- 2590 Views
Last post by cruser
- 1970 Views
Last post by GazmorGuri75
