IPD sale Volvo Parts
damage to turbo after impact/single car accident
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
AnnBart
Year and Model: 2004
Post by AnnBart » Mon Jan 23, 2012 5:22 pm
I hit a pothole or something in street. I could hear the impact. A couple of hours later after parking car I began to drive the car when it starts to smoke from underneath. Lots of white billowing smoke from sides and rear of the car. Dealer inspected car said not damage to oil pan however believes oil entered turbo. He thinks something happened to seals. Prior to impact no issues with car it purrrrrrred on start up and no smoke. What are possible reasons for oil in turbo and/or seal to cause leak considering I am told there is no damage to oil pan or undercarriage? :?:
SimLyons
Year and Model: 2001 V70 T5
Re: damage to turbo after impact/single car accident
Post by SimLyons » Mon Jan 23, 2012 11:15 pm
White smoke pouring out from under the car at a stop or even slow driving is almost cetainly oil hitting a very hot place. 2 places qualify best: Your turbo (exhaust side, connected to the down pipe and Catylic converter) and the exhaust manifold, connected to the turbo. They fry oil when warmed up and white smoke will billow out, not from the exhaust pipe. If any of it is coming out your exhaust you have more problems, but I would guess an oil leak to the hot spots mantioned above. A decent macahnic can put a dye in your oil and trace any leaks with a black light.....if he/she can't spot it with no help.
Sim
fazool
Year and Model: S60, 2007
Been thanked: 2 times
United States of America
Post by fazool » Tue Jan 24, 2012 6:27 am
I believe your mechanic is mis-speaking.
Your turbo seals are essentially internal seals that separate the oil from the air flow. The often fail as they are a highly stressed, under extreme roational wear and pressure and heat.
Smoke from these seals, however, remains in the exhaust system and is blown out the tailpipe.
If you have oil billowing underneath then you have an external oil leak. If it is from the turb, then one of the turbo oil lines are damaged, not the seals.
You didn't mention your car model but one of my Volvo's has an oil trap and some oil lines right near the front suspension and that type of thing could blow oil onto my hot exhaust system, making the symptoms you described.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
Jarman06
Year and Model: 2014
Post by Jarman06 » Fri Jun 08, 2018 4:41 am
I know it’s quite an old thread, however, something very similar happened with my friend and in his case, seals had got damaged and he had to replace complete components. He is now working for a DUI attorney Los Angeles and I will try to find more on that from him.
Who is online
Users browsing this forum: firstv70volvo, IslandV70 and 41 guests
