2004 v70 Flushing Power Steering System
2001 - 2007 XC-70
Faust
Year and Model: XC70 2005
Has thanked: 14 times
Been thanked: 4 times
Post by Faust »
I recently topped up my power steering with ATF, as per the manual. I have since learned that I should have used Pentosin. Additionally, the pump is making more noise and the fluid looks a little "funny". I would like to drain it and replace it with 100% Pentosin. Any suggestions on how to do that?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
KurtL
Year and Model: V70 2001
Re: 2004 v70 Flushing Power Steering System
Post by KurtL »
I just used the pump off an old shampoo bottle to suck most of the fluid out of the reservoir and refilled it. I repeated this a couple of times to switch out the fluid nearly completely.
Faust
Post by Faust »
KurtL wrote:I just used the pump off an old shampoo bottle to suck most of the fluid out of the reservoir and refilled it. I repeated this a couple of times to switch out the fluid nearly completely.
That is what I was thinking, I have a vacuum bottle kit for one man brake bleeding. I wasn't sure if the reservoir was simply a reservoir, but having two hoses I assumed fluid was constantly passed through it for cooling, or some other purpose.
2004 V70
oragex
Year and Model: S60 2003
Has thanked: 100 times
Been thanked: 308 times
Post by oragex »
Actually you can just free the two hoses running from the reservoir and pull up the reservoir and just pour the fluid from it, it works. If you intend to also remove the coolant reservoir, I recommend unplugging the level sensor because the sensor wire is short and it breaks easily (causing a low level message).
