Did you know? 🤔
Sourcing Rebuilt Volvo Axles
2001 - 2007 XC-70
jbeebo
Year and Model: S60, 2005
Has thanked: 0
Canada
jbeebo
Re: Sourcing Rebuilt Volvo Axles
Post by jbeebo » Sun Sep 03, 2017 8:37 pm
Definitely not machinable. These things are optimized to the n-th degree and machined, hardened and ground to mind-bendingly complex 3D geometry. They fit together like a puzzle. Once you get it apart you'll see what I mean. Even if you could machine the channel to accept larger ball bearings and get it re-hardened and ground to the right geometry, you would restrict the movement of the joint with larger balls.
You could swap out one side of the axle with a rebuild, but if you're going that far might as well rebuild both sides and just swap the whole assy.
If yours are worn, I'd keep them on the car and deal with the noise and vibe until you get a chance to rebuild the other set. That or buy 2 sets, one to swap on right away and the other to rebuild and swap out shortly thereafter. I just exchanged mine again this weekend as I'm refreshing the steering and suspension components, so now I have a spare set again I can rebuild in due time :-)
My original set lasted ~110k miles. Second set used from Erie had 56k (R side) & 82k (L side) miles, and the 82k one lasted another 40k miles before boot failure. The 56k set (now with 106k miles), boots are still intact but passenger side idler bearing was starting to get sloppy. In other words, these axles last about 110k miles in my region - this will give you an idea how far you can push it.
2005 S60 2.4L (B5244S6), 175k miles
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 23 times
chrism
Post by chrism » Sun Sep 03, 2017 9:30 pm
I'm at 180,000 miles on the originals. The boots are still in tact but it's a rough runner. It smooths out somewhat at about 82 mph.
jbeebo
Has thanked: 0
Canada
jbeebo
Post by jbeebo » Mon Sep 04, 2017 12:10 am
I'd say you got your moneys worth out of those axles, and I'm guessing your inclined to drive 82mph these days :wink:
FYI - some pictures of the outer joint guts.
viewtopic.php?f=9&t=81809&hilit=cv+join ... 10#p444053
stuartg3
Year and Model: 2003 V70
Has thanked: 0
Been thanked: 0
stuartg3
Post by stuartg3 » Sat Oct 12, 2019 3:16 pm
If I were to look for a set of used OEM axles to rebuild, can anyone tell me how I would go about verifying that they were OEM? Does anyone know which cars had the same axles? (2003 V70).
I had actually rebuilt the originals once before and then when the boots split the next time, I (foolishly) bought a set of reconditioned axles. These recons have not held up that well.....
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 277 times
Canada
oragex
Post by oragex » Sun Oct 13, 2019 4:52 pm
OEM have the Volvo sticker to them, at the bottom of the sticker you have the manufacturing date. Also notice the GKN brand - this is the boot brand to buy for replacement
GKN drive shafts and boots:
https://www.carid.com/2003-volvo-v70-dr ... %5B%5D=GKN
They also come originally with heavy duty clamps like on this one www.youtube.com/watch?v=1mkWzAaHyJE
The best choice would be an OEM one that was recently completely replaced. Many get just the outer boot replaced - replacement boot is hard plastic
Getting a used axle is a gamble - even with just a slight play to them, they may vibrate on highway
Not 100% sure but I think compatibility wise is all about having the same transmission. There are about 2 automatic transmissions I think, the Aisin 5 speed and the Aisin AWTF-80 SC 6 speeds with man shifting - at least the right drive shaft is longer on the 5 speed.
