Did you know? 🤔
What did you do to your P2 Volvo today....now sticky!!
2001 - 2007 XC-70
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 26 times
United States of America
MDK
Re: What did you do to your P2 Volvo today....now sticky!!
Post by MDK » Wed Jun 05, 2019 6:34 pm
Hey boys and girls...I did the same thing that I did yesterday .. but to the R car. I did a complete flush on the trans fluid with 12 quarts of the aisin T I-V a few weeks ago. Today I pulled the drain plug, cleaned the magnet. Added the other half of the bottle of lubegaurd.. put in 3 and a half quarts of fluid. Replaced trans torque mount.
KidsV70
Year and Model: 2002 V70
Has thanked: 2 times
Been thanked: 0
KidsV70
Post by KidsV70 » Wed Jun 05, 2019 10:28 pm
(This was a few days ago, FYI)
An oil change and replacing the passenger side lower engine mount. It was the longest oil change I have ever had to deal with because the previous oil pan bolt had just barely been in there and proved impossible to reinstall. I had to order a longer one.
The most interesting part was replacing the lower engine mount. It didn’t fail in the usual way, instead the rubber deteriorated on each side which allows the engine to tilt back and forward. It made a popping noise at the passenger (right) front on acceleration and deceleration. Accelerate, “pop”, then let off on the gas and “pop” again. From what I’ve seen online, it’s an unusual failure mode. So I figured I’d share. I’ve attached pictures; note the deterioration of the rubber at the sides of the steel the bolts to the engine. I can tilt the mount back-and-forth with my hand.
Cheers,
Bert
HankScorpio
Year and Model: 2006 V70R
Has thanked: 0
Been thanked: 0
Great Britain
HankScorpio
Post by HankScorpio » Thu Jun 06, 2019 7:56 am
Took my newly acquired v70r to the garage to check underneath and all four quarters. Passed with flying colours and even though we were talking and fiddling for over an hour, they still didn't charge me :D
Advice worth what you just paid for it
MDK
Has thanked: 0
MDK
Post by MDK » Thu Jun 06, 2019 5:10 pm
New lower A arms installed on my 2002 V70 NT. ...
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 17 times
XC70Rider
Post by XC70Rider » Sun Jun 09, 2019 8:26 pm
New Lemforder front sway bar link on passenger side. The driver's side looked fairly new with a galvanized rod and good bushings so previous owner must of only replaced that one.
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 16 times
Been thanked: 19 times
Netherlands
ndphotonl
Post by ndphotonl » Thu Jun 13, 2019 12:08 pm
Swapped the 13T turbo for a 16T turbo and also made the change to an external CBV/Diverter Valve. I swapped over the wastegate actuator from the 13T, so it still makes 0.5-0.6 BAR, but it feels a lot more potent.
ImageVolvo S80 2.4T TD04HL-16T vs 13T turbo by Andy Ramdin, on Flickr
For an external DV, I used the first hose from the intercooler exit and made a 25mm connection. I used a Bosch 710p diverter valve, which has a 25mm inlet+outlet.
ImageVolvo S80 2.4T External DV by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
Antoine240bk
Year and Model: XC70 2.5T-2006
Has thanked: 10 times
Been thanked: 13 times
France
Antoine240bk
Post by Antoine240bk » Sat Jun 15, 2019 1:31 pm
I finally managed to fit the right Banjo bolt for the Pcv system, so this is done for all!
Checked the timing belt to see if there was any leaks behind the cams.
To my surprise there is grease on the belt.
Wait! :o it's not oil it's grease!
The bearing of the tensioner is leaking.
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
Has thanked: 192 times
Been thanked: 619 times
Trinidad & Tobago
Post by abscate » Sun Jun 16, 2019 4:28 am
Le Sommer....a great time for a timing belt job and a great lady for scoring goals!
Vive la France!
XC70Rider
XC70Rider
Post by XC70Rider » Sun Jun 16, 2019 7:22 pm
Removed the rear bumper to replace a faulty backup sensor. REM-4F45 diagnosed the far right backup sensor was broken. Removing the rear is a PITA compared to the front bumper! Had to drill out the rivets so might of never been removed. Popping the black inner panel off the bumper was also a headache.
Volvo wants $90+ for each sensor so I got 2 aftermarket ones on Amazon for $11.89 each.
oragex
Year and Model: S60 2003
Has thanked: 81 times
Been thanked: 177 times
Canada
oragex
Post by oragex » Mon Jun 17, 2019 10:26 am
Could it be grease from the nearby CV joint ? Which brand the tensioner ? I put a Dayco kit and boy it didn't last. The belt was almost in pieces after 20000 km, the roller was throwing grease right from the start, the tensioner was running dry too. Also careful if the water pump was replaced with anything but Aisin
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
