IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
A different issue with the B4 servo piston
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 297 times
Post by oragex »
Hello everybody, I spent a few hours inspecting the B4 servo piston on my 2003. Reason was harsh up-shifting 2nd to 3rd with some delay and harsh engagement. I wondered if the servo cover had the know issue, but the cover was in perfect condition. Rather, there was an issue with the piston itself, explained later in the video. At same time, I resume the already known difficulties of this not so pleasant job, hopefully it will help someone. The video is not the best given the location of the servo cover on the transmission
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 7 times
Re: A different issue with the B4 servo piston
Post by Tonyx »
This is interesting observation. We know the shifting gets worse as trans oil warms up which means the piston you refer to also heats up and expands making gap between piston and cylinder smaller. And if any scratch is there, it will likely exacerbate mobility of the piston. Hmmm, interesting..,
2003 XC70 230K and counting..,
oragex
Post by oragex »
That's right. This might be the fix for 2003-2009 that have transmission upshift issues from 2nd to 3rd gear.
Ragman
Year and Model: V702.5T 2007
Post by Ragman »
Nice post. I believe I have the same issue with my 2007 V70 2.5T transmission, which seems to delay/slip into 3rd gear. I've purchased the B4 servo cover kit from IPD, but have yet to do the install. I was also going to change my fluid After the cover replacement , but now I will also look for the roughness on the piston and in the piston sleeve. Just wondering where I can buy the mesh/wire sponge you mention in your video? Thanks for a great tutorial.
86 740T M, 98S70T-5 M x2, 07 V70 2.5T
oragex
Post by oragex »
It's a typical wire sponge for kitchen. A quality one is important so it doesn't break into tiny pieces. Also important part is to use a light one as there are also heavy duty ones and these may be too rough for the metal surface. Let us know if it helped with the gear shifting :cool:
precopster
Year and Model: Lots
Been thanked: 110 times
Post by precopster »
Great observation on this piston problem.
Slamming or hard engagement from 3rd to 2nd gear may be attributed to this rough bore issue. As revs increase and the shift timing is compromised the transmission slams when the piston finally moves.
It pays to say here that when a new B4 cover is purchased you get 2 new o ring seals. One is for the piston and the other for the new cover. A new seal is recommended if it is at all damaged such as yours.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
JRL
Year and Model: Several
Been thanked: 12 times
Post by JRL »
B4 servo has NOTHING to do with a bad 2-3 upshift or downshift, only 3-4
This is a VALVEBODY issue
Contact info for purchases: [email protected]
oragex
Post by oragex »
precopster wrote:Great observation on this piston problem.
Indeed, not having new seals at hand, I switched the damaged seal from the piston with one of the two from the cover.
precopster
For JRL's sake:
From IPD's website: The early AW55-50/51SN five speed automatic transmissions have an issue with shift “flares” and other odd symptoms related to shifting in and out of 3rd gear. This usually reveals itself by a “missed” shift (sometimes called "shift flare") from 2nd to 3rd gear on a random basis.
On XC70.com : http://www.volvoxc.com/forums/showthrea ... ervo-Cover
The B4 cover TOTALLY FIXED 2ND TO 3RD gear on my 2000 v70 NON TURBO 5 years ago (4TH to 3RD harshness is now its forte)
In fact if band is worn outside of limits there is NO 3rd gear as was the case with our own 2002 XC70. I renewed 3rd gear by replacing the friction band (a job not for the faint of heart by the way)
JRL
Post by JRL »
We can agree to disagree a bit here.
I tend to believe my factory rep (who is an engineer) who told me this.
ipd is not always the end to end alls regarding Volvo issues and they too can be incorrect at times.
While is may help on certain transmission, the B4 servo IS primarily for 3-4 shifts not 2-3 shifts.... up and/or down
