IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Genuine Volvo ATF is NOT Mobil 3309...
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 75 times
Post by vtl »
... as proved by a complicated viscosity test :)
Not yet in my transmission, but that will be addressed pretty soon.
What I basically have is a slight jolts during upshifts. More pronounced when hot, less when cold. Tried too many JWS3309-compatible fluids: Mobil 3309, Idemitsu Type-TLS*, Valvoline MaxLive, Aisin 0T4, all kicks my back. The only exception, if memory does not lie, was Amsoil: with Amsoil transmission shifted too quick, it felt like somebody was stepping on car's tail.
[*] Idemitsu worked great in my other P2 wagon after I replaced the valve body. Though the engine was weaker than in XC70, way weaker.
05 XC70 265k, 16 XC60 45k, 19 Tundra 5k
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 297 times
Re: Genuine Volvo ATF is NOT Mobil 3309...
Post by oragex »
vtl, can you do this test again and include the Toyota type-IV ? It would be interesting.
As for MaxLive no more for me, the fluid shrinks too much with temperature and in cold weather it just didn't behave like the mobil or toyota one.
vtl
Post by vtl »
oragex wrote:vtl, can you do this test again and include the Toyota type-IV ? It would be interesting.
That was my feeling too: worked great during summer being mixed 50/50 with Mobil, but started misbehaving with the colds.
I'll grab a quart of T-IV.
Here's an earlier test (if that can be called a test :) ) for Aisin 0T4 and Mobil 3309:
keaunym
Year and Model: 2009 Volvo S60 2.5T
Post by keaunym »
I'm about to drain and fill my transmission. Transmission shifts beautifully and the fluid looks healthy red. It may or may not have been changed before--not sure the service history--just got it and it has 84,000 miles now.
What is the verdict? 12 quarts of Mobil 3309 was what I was about to order off of Amazon. What fluid should I use instead?
vtl
Post by vtl »
Mine did not ever shift properly since I started to play with aftermarket fluids at 79k. I'll try to find time this weekend and flush with OE ATF, will share experience.
keaunym
Post by keaunym »
What is the best source for Volvo fluid (lowest price per quart)?
vtl
Post by vtl »
I've got three 4 liters jugs for $172.69 (after 5% discount applied) from FCP, including free shipping. That is $14.39/liter.
JRL
Year and Model: Several
Been thanked: 12 times
Post by JRL »
Just because one person is stating something different after 15 years does not mean everyone should change their fluid practices
Mobil 3309 from Amazon is just fine (plus I believe vtl is incorrect but we can save that conversation for another day).
Contact info for purchases: [email protected]
vtl
Post by vtl »
http://forums.swedespeed.com/showthread ... ost2371650
I saw same higher cSt in Volvo tech.manual for EU market found at one of UK sites.
You can continue using Mobil 3309 as long as it fit your needs. Mobil does not work well for me. Never worked.
vtl
Post by vtl »
Went through 11 litres. 2-3 upshift, which annoyed me most, is next to none now. Also car pulls much stronger.
