MVS-Amazon link helps MVS!
S60 taking a long time to heat up
2001 - 2007 XC-70
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 321 times
Re: S60 taking a long time to heat up
Post by oragex »
As JRL, mine takes a while to warm up. We had around 5F this time of the year. I drive the car gently inside city, the needle will be at 10h30 in about 5 minutes. Instead, I let it idle for a few seconds after firing up, then keep the gas at 2500 rpm for 30 seconds: warms up much faster. However I use 0W40 oil, so it's safer to do so on cold engine. The thermostat is 2 yrs old.
To check the thermostat let it idle from cold for 1 min, if the upper hose is warm at it's upper portion, the thermostat is stuck open.
MadeInJapan
Has thanked: 7 times
Been thanked: 27 times
Post by MadeInJapan »
Thanks for the replies- will just keep an eye on things for now! Btw, I looked for that ProParts unit on FCP but couldn't find it. You sure it's for an S60? Earlier models (2001 and '02) apparently can just have a t-stat replacement and not the whole assembly (some non-turbo cars too).
Never mind- found it...that less expensive model if for non-turbo's only. S60 2003-'05 and V70 2003-'07. Don't know why the turbo owner's are more expensive...but design must be slightly different.
JRL
Year and Model: Several
Been thanked: 12 times
Post by JRL »
DO NOT BUY PRO PARTS PARTS
Pro Parts is the old Scan Tech
Contact info for purchases: [email protected]
vtl
Year and Model: 2005 XC70
Been thanked: 96 times
Post by vtl »
In Europe it's possible to buy t-stat alone, it's Gates TH35991.
05 XC70, 16 XC60, 19 Tundra
MadeInJapan
vtl- thanks for the information. I may just buy one to have on hand... our V70 and S60 take the same part!
MadeInJapan
I found confirmation it works here!!!
http://forums.swedespeed.com/showthread ... es-TH35991
